SOURCE: coffee grounds in the cup
since you said usually... I suspect the rubber seal that surrounds the top needle is not seating well...
you can verify this by making a beverage with a k-cup and, just before the water starts, add a little hand pressure to the K-cup arm pushing down a little bit... not hard...
If it consistently makes a good beverage, then we focus our attention to that piece of the brewer...
when the consistency of the water changes, it tells me to look for leaks or unusual percolation of water...
you can verify the K-cup holder is ok... but another way to simulate the hand pressure is to put a shim of some sorts under the lip of the k-cup... like the thickness of a couple sheets of paper under the rim... not the actual k-cup... but the k-cup holder... raising it up a smidge is the same as the slight hand pressure...
I would look to see if the rubber seal has come loose around the top needle....
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
SOURCE: My brewer has 3 settings
Your problem is on the setting section of the coffee maker. Try to check if there is a visible adjuster knob or variable resistor to adjust the setting for the mug and the large mug. If there is none the adjustment is to be done by opening the system panel of your coffee maker.
SOURCE: keurig platinum brewer says "not ready"....will
sounds like a bad machine, you can try contacting Keurig directly and see if they will honor the warranty, if that doesnt work i know of this great website that sells all kinds of keurig products and parts for very cheap.http://stores.ilikenew.com
SOURCE: My Keurig model D70 does
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
