Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
Anonymous Posted on Mar 01, 2008
Password I am trying to add another computer and I have forgotten my password. How can I find it, and if I have to reset the router will I need my setup disc I can't seem to locate that either
Anonymous
Level 2:
  • Expert 47 Answers
  • Posted on Mar 01, 2008
Anonymous
Expert
Level 2:
Answers
47
Questions
0
Helped
43010
Points
111
You need to reset the password for your router .Press and hold the reset button on the back of the router for 30 seconds. This will clear your NVRAM, the configuration and reset the password to admin. Username is not required.
If you didn't change any settings on the router then you don't need the CD. You can also download the wizard at linksys website.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740145678B574
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3976&lid=3745237401B04
Password forgotten
try getting the pervious owner to call the provider and they should replace it after asking a few security questions
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
I have linksys wireless router and am trying to get wi fi on a recently purchased Kindle but Have forgotten my Linksys password. Please help
Hi nancylousdol,
If you have forgotten your password you can reset the router to its factory state and setup a new password for it. Resetting the router will wiped out all changes that have been saved. To reset the router, look for the small hole at the back of it. Press and hold it for 10-15 seconds using a Pen or Paperclip. Then access the router settings page so that you can personalize the settings.
For you to access your router you need a working computer that is connected to the router and open a browser type 192.168.1.1 to he address bar and it will ask you for a username and password. The default username is "leave it blank" and the default password is admin.
Rate me if this helps so i can help others.
Thanks for using Fixya
I have forgotten my password to add other items to wireless router. How can I retrieve the old password, or how can I reset it?
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Default password is admin
Step 4 : Click wireless
Step 5 : Choose wireless security
Step 6 : Here you can find the Password
Step 7 : Try to connect with this password
let me know if this works
Regards
TOM
I have a new computer and have forgotten my password to protect me .Can i make a new password by installing the set up disc in my apple?
If you have forgotten the password for your Linksys router and are not able to connect your new computer then try and follow the below steps:
WARNING: This would reset the router to it's factory settings (it generally does make a difference unless it's a gateway & you don't remember your ISP credentials. In your case it should be OK)
1. at the back of you Linksys you'll see a red button that says Reset2. Press and hold it for 30 seconds (this to set your router to default settings)3. Now open a web browser (say Safari) & go to http://192.168.1.14. Leave Login as blank and for password enter "admin"5. You should now see the Basic Setup page, at the top click on Administration option6. Under Management web page you'll see 2 text boxes, you should enter a password of your choice here (this would secure your router). At the bottom of the page click on Save Settings7. You'll be asked to login again, use the password you just entered
Your Linksys router is not secured. Hope this helps, please let me know if you need further assistance.
Have forgotten NetKey password to add laptop to wireless network
Just reset the router and you can configure it again like before.
2answers
I need the driver wgt624 v3
The router's doesn't require driver to work. It can be setup using the router's Admin page. Try to reset it first, make sure you have a broadband connection. Connection should be as follows
Modem > Internet port of router
Computer > port 1 of the router
2answers
Linksys wireless-G router
I’m sorry to tell you what the only way is the hard way.
Find and press the reset button on the back of the router.
Now - hopefully you remember how you set up the router previously, or you have to do this at the same time in all the computers on the wireless network.
NOTE. Do use cable between the router and the pc you perform setup with.....
Please vote if this help you.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
