Casio OC500 Oceanus watch Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hallo, i bought casio oceanus ocw 650 T and i cann not set up the time manually. All hands are on starting position 12 o clock. Can you help me, can you send me email on [email protected]? THX. GUlic Slovakia
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Feb 23, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1292018
Points
7081
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
3helpful
2answers
Casio module 5410 has stopped completely in the 12 o’clock position on all hands any ideas to get it started again
Page E-72 of the online manual at the link below suggests it may take some time to recharge after exposure to light, but unsure if that is your issue or not.
https://support.casio.com/storage/en/manual/pdf/EN/009/qw5410.pdf
2helpful
I am trying to set the correct time on the Casio Oceanus 4364 but can't get it to timesetting mode correctly.
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
3helpful
I have an OCW-M 800. I have downloaded the manual from mfg. website and cannot seem to get it to set the time for EST correctly. THis watch cost me over $500.00 and is so complicated that I fear I have...
I am not American, so I am not familiar with the definition of "EST" or which of the four "city" settings is correct for you.
Having read the instructions I see that for America you have to select "USA" first and then the appropriate city, have you done this?. The list of four options covers 4 time zones, so you should be able to get the correct time for your area.
When I bought an atomic watch recently, I had to leave it overnight to catch the timekeeping signals. I see that you posted your question only 14 hours ago. How long have you had it. GIve your watch a day or so for it to latch on to the correct time.
Check that the "autoreceive" is "on".
Check that the daylight saving time (DST) is correctly set. The manuals indicate that some areas may not be using it?
Keep trying - it is nice to have a watch that is always correct!
16helpful
2answers
Casio edifice EF534D, The seconds hand does not come back to 00 on pressing the reset button. what is the problem, how do i solve it??
Have you solved this yet? I have a reset process that sets the starting position back to 12 o'clock. Pull the crown to the second (outmost) position and then start pressing the start-stop button repeatedly. Each push will set the starting position by 1 second, until you get to 12 o'clock, then push the crown back to its normal position. Let me know if that works.
Sep 18, 2010 • Watches
My Oceanus watch model no. 4749 stays 1/2 hr slow. I manually reset it to the correct time and it resets itself to 1/2 hr slow. I have it set at central time
You can get manual information from the Oceanus web site (NOT casio strangely enough!).
Insert "www.oceanus-us.com/" into your search engine
Select "support", then "Manual information"
Enter your model number and download the information. There are instructions on choice of home city and further adjustments if it still is not correct after initial setting up.
Minut indicator is out of sync. Reset sets cursor
1. Look in the back of your watch, it will show the model number (in a square on top of "CASIO")
2. Look at this web page for the right manual:http://www.oceanus-us.com/index.php?fuseaction=support.content&CNT_ID=14884814-F2AB-46E6-93DC-5E678BD11926
3. Look at the section "Adjusting the Home Positions" - that is where the answer is.
6helpful
2answers
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 • Watches
3answers
Casio Oceanus Atomic Setting
I also have an OCW-M700 and found the instructions that you download from the casio website good and perhaps easier to follow than the booklet, still does need some patience and but worth it in the end because it is a great watch. The manual time/date setting can be done fairly easily once you are in 'Timekeeping mode' (page 4, bottom right). The applicable download is operation guide 4749. Good luck. Also, you probably dont want to know this but for others out there - they sell for around 600US$ in taiwan if you can find a shop that stocks the casio upper range, taipei airport normally has stock at duty free.
Jan 05, 2008 • Watches
58helpful
7answers
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
