Music Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
XR 8600 what color wire on the output connects
XR 8600 with XLR cable, what color wire on the output connencts to what lead on the speaker? We have four wires colored red, white, black, and green. Wanting to connect two seperate speakers. Should we be running series or parallel?
Anonymous
Level 3:
  • Master 417 Answers
  • Posted on Apr 01, 2010
Anonymous
Master
Level 3:
Answers
417
Questions
6
Helped
179098
Points
1147
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
1helpful
2answers
How do I connect my Bose l1 compact to Peavey xr 8600?
You would come out of the Main output on the front of the mixer into the line in on the Bose.
You may find this site useful- L1 Unofficial Performers Guide
Can you run a powered mixer without a speaker load
Yes.
The only thing the power does is power the speaker outputs. (Main out) or (aux out if available)
so if u want to just use the headphone jack or whatever it is your doing your not going to hurt the mixer by turning it on without speakers connected to it.
Q: What is it that u are doing?
I'm using the Peavey XR 8600 with two EV Force i 25 speakers. My question is this, what is the difference between the two outputs on the Peavey? I naturally assumed one was left and one was right....
DO NOT parallel more than two 8 ohm speakers on either output and you will be OK. You could also use one speaker on each output. That would be easier on the equipment as it would be an 8 ohm load on each instead of a 4 ohm load on one of the internal amps. If you want to drive stage minitors, then you existing setup is fine and you will connect the monitors to the second speaker output and set the Mon switch as MAIN/MON.
1helpful
I have a peavey 8600 powered mixer. If i run powered speakers through the main output on the front will I not have effects?
If you run the speakers FROM the main you should have BOTH the effects and the EQ invilved with your signal.
I have the peavey 8600 and l was doing karaoke at my bar last nightwhen something weird happend. i plug my karaoke eqpment into the last channel at the rca in and last night that channel lost half its...
Iis ALL your equipment powered from the same receptacle? It had better be... ground bounce can destroy input circuits in these units. I don't have the schematic but a common problem where XLR connectors go into a mixer is they have radio-frequency noise suppression caps to ground from each side of the XLR input. These caps are often lower voltage rating and can be popped by ground bounce or ungrounded equipment being connected before the ground connection is made. When one goes, there is loss of half the voltage or 6 Db of power gain. Since these RCA's are right at the XLR they MAY connect and have these caps and one may have shorted. That means the repair shop I am afraid unless you are adept at electronics. Most of these mixers are a pain to work on that area as all the knobs and screws have to come out/off to get the circuit board away from the panel to work on... I wish I had the service manual to give you more info...
PLEASE in the future power all equipment from the same receptacle or power source AND for units that don't have three wire power cord, NEVER change cables that can break the ground connection such as the RCA cables while power is on to any of the equipment. This will save repair bills...
This is from your friendly electrical engineer that works with this stuff and repairs his own...
2helpful
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
4helpful
2answers
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
1helpful
I want to use both speaker outputs for loudspeakers on my Peavey 8600 without splitting the watts. How do I hook up monitor speakers in this situation? Can another mixer be patched into the front? I have...
Sorry, but this unit does NOT support "bridged" mode. You will have to drive seperate speakers from the two seperate outputs. You would NOT get any more power if you could do bridged mode than you could with 4 ohm speakers on each of the two output channels.
2helpful
How do i connect 2 monitors to the one monitor output jack on the peavey xr 600c mixer..cheers My product not quite the one as listed from your product database but may be similar
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
