Re: Do the clock mechanisms on these units fail? I
Yes, they can fail. Like any mechanical device, the timer motor can quit. I recently replaced one at work for that reason. To be honest, I don't know if it's possible to get the motor separately to repair one of these. It's probably just as cost-effective to replace the whole timer anyway.
Cross-over wiring is as follows: Paragon terminal 1 goes to T101 terminal 1 Paragon terminal 2 goes to T101 terminal 2 Paragon terminal 3 goes to T101 terminal A
Add a comment for more free help. Also take advantage of fixya phone service. For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project. Fixya is always less expensive than a service call.
3) If you have different timer than T101-103-104, then add a comment.
4) Clock motors are located on back of mechanism. Mechanism snaps out with thumb spring located top inside box. Clocks have identifying numbers: google search for that clock number if different that shown above.
6) Add a comment for more free help. Also take advantage of fixya phone service. For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Sounds like the clock motor has gotten weak. You can replace Intermatic clock motors.
Snap out insides of timer and clock motor is located on back. Motor has numbers printed on it that identify specific clock motor.
Motor is removable with small star screwdriver bit. Clock motor has white wires that attach to terminals on front of mechanism. Re-attach new clock to same terminals and tighten screws very tight.
How Intermatic dial timer clock works. Clock motor rotates dial. Intermatic clock motor, located on back of mechanism, are replaceable Trippers located on outer edge of dial push on-off lever ON tripper pushes lever one direction OFF tripper pushes lever opposite direction. Lever pushes electrical contacts together and pulls contacts apart. When lever moves, manual override also clicks back and forth with audible click. To replace timer, replacement snaps into box without needing to changing box.
You can replace clock motor on many Intermatic timers: Snap mechanism loose using metal spring top inside box. Tip mechanism out and get clock motor number off motor. Google search specific clock motor number.
