OK well in that case you could convert them to WAV and join that and play it that way?
Download and install the Switch Audio Converter. Switch can convert between numerous audio file types and has the capability of reading MSV files.
Add the MSV file you would like to convert to the Switch converter. Click on "Add File(s)" and browse for the file in the search window that comes up. When you locate the file, click "Open" to import it to the converter.
Select WAV as your output file type. The .wav extension is one of the options in the "Output Format" drop-down menu at the bottom-left corner of the Switch screen.
Choose an output folder for your WAV file. To find a folder, click "Browse" next to the "Output folder" box. Locate the folder where you would like to save the WAV file on your hard drive and click "OK."
Click "Convert" to begin the conversion process. The "Convert" button is in the bottom-right corner of the screen. When you click "Convert," a small window with a progress bar will pop up to monitor the status, and a pop-up message will inform you when the conversion is complete. The WAV file will now be available in your chosen output folder.
http://www.softplatz.com/freeware/wav-joiner/
http://download.cnet.com/Switch-Audio-Converter/3000-2140_4-10703967.html
