If it does not heat , and you already checked the burner and the ignitor, then it is probably the thermal fuse at the back of the appliance.
See the following suggestions from Repairclinic:
No heat
If your dryer doesn't heat, check these:
IgniterGas valve coilsThermal fuse
Igniter
Modern
gas dryers use an electric igniter to ignite the gas from the gas
valve. When it's working properly, the igniter glows bright orange.
When it burns out, the dryer tumbles but there's no heat because the
gas can't ignite. When the igniter burns out, you need to replace it.
If the igniter is held by a tension bracket, you very well may need to
replace the bracket too.
The igniter is inside the dryer
housing, near the bottom front, usually in a cone-shaped metal tube
(the force cone). It's about 2 inches long. It's mounted to the far end
of the burner tube, and it has two wires attached to it--or to the
tension bracket, if there is one.
Gas valve coils
Watch
the igniter. Does it glow bright orange, then shut off without igniting
the gas? (When the gas ignites there's a large blue flame.) If so,
there may be defective coils on the gas valve. Mounted on the top of
modern gas valves, there are black electrical coils. The coils, when
energized, open the gas valve. If one or more of the coils are
defective, the valve doesn't open and the gas cannot ignite. Because
it's often difficult to properly test the coils, it's usually best to
replace both (all) of them at the same time.
Thermal fuse
On
many dryers, there's a thermal fuse (a heat-sensitive fuse that blows
if the dryer overheats) mounted to the exhaust duct inside the back
cover panel. The fuse is about an inch long. It's usually embedded in
black resin and mounted in a white plastic housing.
If the
fuse has blown, it has no continuity. When this happens, your dryer
either just stops heating, or it doesn't work at all. Be sure to
inspect the venting/heating system before replacing the fuse to put the
dryer back into operation. (You can't re-set this type of fuse.)
