Express Thaw comes on when refrigerator door closes. Freezer @ 23F Set @0 Refrigerator @ 42F Set @ 37
INSIDE DOOR LISTS THESE NUMBERS: PSC23NG PS123NG PSH23NG PSC23SG PSI23SG PSH23SG IT IS STAINLESS STEEL SIDE BY SIDE
Thank You
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
After you reset the the indicator, did the light went away because my didn't.
After you reser the indicator, did the light goes off?
Yes, the light returned to its normal function. Are you sure you depressed ALL THREE BUTTONS AT THE SAME TIME holding then down until it beeped (5 seconds)?
It worked great did not have to order a board
G.E. profile Refridgerator stopped cooling completely. Help!
Mine did the same thing, I found the answer here on fixya.
Express Thaw
Doing this makes it beep 3 times and resets the board so the thaw led turns off for good.
Neal in Cookeville
To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps: Adjust Freezer Temp (Warmer) Express Thaw Adjust Refrigerator Temp (Colder)
