KitchenAid KESC307 Electric Kitchen Range Logo
Posted on Feb 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchen Aid KESC 307 hbs4 electric range control
The oven is not working, and one of the range's surface cooking areas is also not working. The reparir person indicated that the problem was the range control unit. He suggested it be replaced.
Wher can I find the control unit and what is the cost.
Cesar
  • Anonymous Mar 17, 2014
    We are on our second KESS908SPS range in a month. Two burners have postage stamp sized black areas that are part of the coil area. A whirpool repair tech was set to replace two burners on the first unit, but we got the store to exchanged it. The replacement range has the same apparent bad areas on two burners and the delivery guy said they all look like that. Bad design, poor engineering, defective parts and no quality control. Either we get one that works out of the box or we go elsewhere. A brand new kitchen deserves better.
Ron Coons
Level 3:
President:
  • KitchenAid Master 2,651 Answers
  • Posted on Feb 24, 2008
Ron Coons
KitchenAid Master
Level 3:
President:
Answers
2651
Questions
Helped
1547574
Points
7824
Oven not workin very well might be a control issue, but top elements work completly seperate from oven control, and theres 2 electronics there $200 for touchpad galss assy and $375 for electronic timer, and switches for the burner might be 50.id make sure I trusted the repairman's diag before proceding
Oven does not work on kenmore electric range
You may have an open neutral (center) wire in your 220V (or 240V) wall outlet (or where the wires go into your range). Your Electronic Oven Control (EOC) and light bulbs operate off of 120V, which it gets from one leg of your 240V outlet to neutral. You surface elements don't use the EOC, but are directly connected (when on) to both legs of your 240V Power. So unplug your range, and remove the access panel to your electrical connections at the bottom back of your range. Make sure the center screw that the white wire is connected to is tight. If that's okay, then the problem is probably in your electrical wall outlet, and you should contact an electrician to check it and fix it.
Hello... range reaches desired temp, food in oven, Beeps F-1, shuts down oven, food not cooked... huge problem kitchen aid supra electric range
You may need to see the secondary error code (F1-E?). The chart below is for a KitchenAid Range. Most likely is a control board issue. We rebuild control boards if you want to save some money compared to new.
9helpful
2answers
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
1helpful
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
I cannot turn top oven off from bake. How do I make it work?
have the same problem with kitchen aid stove. Set the cook duration for one minute - then open and closed door. Oven turned off.
Broiler coil sparked and broke, stopped working; 1 1/2 weeks later bake coil burnt out. I got new coils from the manufacturing, and had someone install. They don't work. The surface cooking area works...
Installer either did not do the job right OR when the coils broke they shorted in a manner that fried the oven control. The installer SHOULD have verified proper operation before they left your premises.
Blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
6helpful
2answers
2helpful
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
