SOURCE: JVC Enverio GZ-MG155 30gb camcorder
Try removing the battery and see if it changes back to the default settings.
SOURCE: Looking for a info manual for usgae
You should first check the JVC website for a manual. This is a recent model and a manual should be available for free download. Another option is a website called safemanuals.com. They have a massive database and often can supply manuals that are not available elsewhere. The specific supplier is diplodocs and you will need to create an account. Its free and easy. Good luck
SOURCE: How to use an SD card to record on a JVC GR-D370 mini DV?
Download PC Inspector File Recovery.Thank
SOURCE: "please insert memory card in GZ-MG130U CAMACORDER
You need to tell it in the settings menu that you want to record to the hard drive instead of the SD card.
SOURCE: Our JVC Everio GZ-MG27U Camcorder
It seems that your lenses are stuck, take it to a certified technician and ask for them to repair it.
I'd appreciate if you rate this 4 thumbs if I had helped you. If I couldn't help you please rate accordingly.
