20 Most Recent Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Questions & Answers
Nikon Coolpix s550: Screen won't work
Please make sure no cable is attached to the camera. On many Nikon cameras, connecting a cable shuts down the screen.
11/11/2017 11:30:09 PM • Nikon Coolpix... • Answered on Nov 11, 2017
My nikon s550 wont turn on
Battery any good? Have an adapter? If both do not restore operation, you might want to check to see if your camera has a default restore button.
4/29/2017 3:25:20 PM • Nikon Coolpix... • Answered on Apr 29, 2017
Delete pictures
http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/S550_en.pdf The link above will take you to your camera's manual. You did not say if you want to delete a few pictures or all of the pictures from your memory card. If you want to erase all of your pictures, you must reformat your memory by following the instructions on page 19. If you want to remove selected pictures, look on page 102 for instructions.
12/25/2014 4:54:07 PM • Nikon Coolpix... • Answered on Dec 25, 2014
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
6/14/2014 2:06:04 PM • Nikon Coolpix... • Answered on Jun 14, 2014
My nikon s550 wont extend
What finally worked for me was a mix of the ideas listed here. I placed a vacuum hose against the lens and turned on the vacuum, then turned on the camera and tried to gently pull them apart. There was just enough suction to pull the lens through the spot it was sticking on and PRESTO! It works again! The focus was nasty at first, but another quick power cycle fixed that up. The lens hasn't locked up again despite many power cycles. I used a proper canister vacuum which happens to have a new bag in it, so plenty of suction.
11/9/2013 4:35:56 AM • Nikon Coolpix... • Answered on Nov 09, 2013
4answers
When i turnon my coolpix s550 screen shows the messaga memory card is write protected i try everything do nothing can you pl tell me the problem thanks
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
8/28/2012 1:11:19 AM • Nikon Coolpix... • Answered on Aug 28, 2012
My machine takes picture more white and linely.
Hi there:A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
7/19/2012 5:25:59 PM • Nikon Coolpix... • Answered on Jul 19, 2012
How do you change the language on a nikon coolpix L1
Press the Menu button. Select Setup (the wrench icon). Select Language (the waving flag icon. In that menu, each language is labeled in that language, so you should see "English" as one of the options. Select that, and everything should be back in English.
4/15/2012 9:39:56 PM • Nikon Coolpix... • Answered on Apr 15, 2012
I was just using my
I'm having the same problem. The first foto looks alright but the rest is as above. I do'nt have a sollution but i had removed the battery and the memory card and left the camera open in the hope it will be a damp issue. just now i take some new foto's and i still got the stripes but i have a picture. Hope some one will have the right sollution.
8/17/2011 6:00:06 AM • Nikon Coolpix... • Answered on Aug 17, 2011
Camera was taken out in
The fault of a the camera is due to failure of the Main control system or the drive. It ispossible that water has seeped into and damaged the board . If so it must be checked in detail to confirm.
Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
8/8/2011 7:11:30 AM • Nikon Coolpix... • Answered on Aug 08, 2011
I have a Nikon Coolpix
Most likely means the memory card is full.
Take the card out, connect it to your computer, click on properties and see how much memory is left on the card. If it is full you need to download or delete imags or anything else you might have on the card.
7/10/2011 5:13:33 AM • Nikon Coolpix... • Answered on Jul 10, 2011
Lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2/25/2011 4:17:26 AM • Nikon Coolpix... • Answered on Feb 25, 2011
Keep getting lens error, stuck in open position
I Hope the steps below should be helpful in fixing your camera issue.
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
2/23/2011 12:34:08 AM • Nikon Coolpix... • Answered on Feb 23, 2011
Hello sir, i bought this camera 2 year before. it
This camera has a fault. You cannot fix it by changing settings. It will probably cost more to repair than it is worth now. You can buy a new camera which will be much better than a camera from two years ago and cost less money.
12/29/2010 2:10:19 PM • Nikon Coolpix... • Answered on Dec 29, 2010
Whenever I take a picture
I´ve got the same problem and think, that it`s the ccd unit.
Someone is offering the lens with ccd unit on ebay.
Best regards
Fite
[email protected]
12/22/2010 1:26:53 PM • Nikon Coolpix... • Answered on Dec 22, 2010
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
Popular Tags
78 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
when turnon coolpix s550 screen shows
  • Cameras
