Buck Dodge Ram 1500 2007 Stereo/radio Wire Harness Plug Dash Logo
Posted on Feb 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size speakers are in an 05 single cab dodge ram 1500?
Anonymous
Level 2:
  • Expert 306 Answers
  • Posted on Feb 06, 2010
Anonymous
Expert
Level 2:
Answers
306
Questions
0
Helped
103478
Points
907
6x9s in the front and 51/4 in rear but will fit 6"
2008 dodge ram speaker polarity
Here is the radio wiring.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
I have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
1helpful
I need to know the universal joint cup size for a
Hello
Drive shafts are
  • Cup Size A= 1.062in.
  • Outside To Outside A= 3.2190in.
  • Cup Size B= 1.062in.
  • Outside To Outside B=3.625in.
  • Frunt axle are
  • Outside To Outside A= 3.625in.
  • Cup Size B= 1.1250in.
  • Snap Ring To Snap Ring B=2.556in.
  • Thanks
    2002 ram 1500 single cab ext light issues
    sounds like a faulty underhood fuseblock..have seen lighting issues with these components
    22helpful
    1998 dodge ram 1500 v85.2 towing capacity?
    according to the owners amnual the max towing weight for a 1999 ram 1500 quad cab wit automatic transmission is 7600 lb.
    with either 5.2 or 5.9 v8. for a reg cab it is 8000 lb.
    Top Buck Car Audio & Video Experts
    xxxxxx xxx
    ZJ Limited
    ZJ Limited
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
