20 Most Recent Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Questions & Answers
2answers
02 dodge ram 1500 4+4.Shaking in front end only
probably are warped machining warped rotors only fixes the problem until they get hot again and they again warp as they are now thinner than before the problem could be in worn suspension rubbers and ball joints so have the front end checked out if it turns out to be rotors , buy quality after market units and quality disc pads have the abs system also checked out as the system indicates a braking action similar to when the abs is activated
1/8/2018 4:03:01 AM • Buck Dodge Ram... • Answered on Jan 08, 2018
We have a 2002 Dodge Ram 1500 that is jerking into
Drain the transmission fluid & remove the filter. Install a new filter & transmission gasket. Noticed the amount of fluid coming out, then put in new fluid at that amount. Open the engine hood. Remove & get access to the MAP/air flash system, clean it out very well without breaking or bending anything.
3/4/2017 3:41:00 AM • Buck Dodge Ram... • Answered on Mar 04, 2017
0answers
CODE P1491
Be the first to answer 9/14/2014 2:46:08 AM • Buck Dodge Ram... • Posted on Sep 14, 2014Be the first to answer
Code p0340
A mechanic always checks for compression, spark and fuel pressure first. Then timing and fuel quality. With timed spark, compression and fuel, there should be combustion. Running then becomes a function of the other control systems.
6/29/2014 3:17:22 PM • Buck Dodge Ram... • Answered on Jun 29, 2014
Heat fan motor debris
Take it out .End clean Debie OutLOL:
11/9/2012 7:38:34 AM • Buck Dodge Ram... • Answered on Nov 09, 2012
Need to find out what
Fig. Cylinder head torque sequence-4.7L engine
Install the cylinder heads. Use new gaskets and tighten the bolts, in sequence, as follows:
  1. Step 1: Bolts 1-10 to 15 ft. lbs. (20 Nm)
  2. Step 2: Bolts 1-10 to 35 ft. lbs. (47 Nm)
  3. Step 3: Bolts 11-14 to 18 ft. lbs. (25 Nm)
  4. Step 4: Bolts 1-10 plus 1 / 4 (90 degree) turn
  5. Step 5: Bolts 11-14 to 19 ft. lbs. (26 Nm)
Hope this helps (remember to rate and comment this answer).
9/9/2011 6:04:24 PM • Buck Dodge Ram... • Answered on Sep 09, 2011
Dodge 1500 service engine soon
Need to get A/C levels checked and might need more freon and go to the auto parts store and have them run an OBD2 scan on your truck. Than go to www.canobd2.com and put your vehicle and code in and see what that code is in reference to.
6/22/2010 7:25:37 PM • Buck Dodge Ram... • Answered on Jun 22, 2010
2answers
Rear speaker does not work
if the car has the factory amp you neeed to turn it on or bypass it to hear the soundin the back call me for more questions at 520-882-8979
6/13/2010 4:38:14 AM • Buck Dodge Ram... • Answered on Jun 13, 2010
P 0700 code on my 2002 ram pickup?
that code is a transmission fault... the quick fix appears to be to check the transmission fluid level and top it up (if needed)
1/11/2010 6:35:19 AM • Buck Dodge Ram... • Answered on Jan 11, 2010
@002 Dodge Ram. Check engine light on. Code 1491
the condensor fan for the a/c is electric and probably has a blown fuse th ecode for a bad ecm (engine control computer ) is p0605 if you don't have that code the computer is likely ok computer failures are rare
9/22/2009 12:51:09 AM • Buck Dodge Ram... • Answered on Sep 22, 2009
0answers
Radio wireharness for 1993 cadillac sts
You can locate your Harness Here Schoche.com Please Rate My Response! Thanks!
2/5/2009 11:25:08 PM • Buck Car Audio &... • Answered on Feb 05, 2009
Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Logo
26 questions posted
Top Buck Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Buck Car Audio & Video
Most Popular Question
need find out
  • Car Audio & Video
