My Wife just inherited her Grandmothers Kenmore 100 stitch, and it did not come with a manual? The problem is that it will only sew in reverse? What should she be checking to correct the problem?
Terry
Could be several things -- motor hooked up backwards, reverse is stuck, etc. Is there a Reverse on the machine? If so, what happens when you activate the reverse. If it then sews forward I would say someone hooked the motor backwards. If there is no change, it would be a problem with the feeding motor or the circuit board. Suggest taking to a reputable service center for analysis. Good luck.
