Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up. 2
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes. 4
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
REVERSING DOOR SWING
Your
dryer is designed so the door swing may be reversed at any time without
additional parts. Conversion is accomplished by transferring hinges to
the opposite side of the cabinet.
To change the direction of the door opening:
1.
Open the dryer door. Remove the four hinge hole plugs from the left
side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Yes ,most dryers will allow this. although you will have to remove door to do it. You should see mount holes on the other side of door sometimes have plugs to remove or srews. The hinges on the door will have to be moved to opposite side. Once again should see mount holes. The whole operation takes a matter of minutes once you see how it is done. Hope this helps
doors are reversible but a little work.once you start taking hinges off you will see inserts that are covered with a plastic grommet.pull those out and put grommets back on other side.you should see it is very easy but time consuming.
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
