20 Most Recent Whirlpool GEW9250P Electric Dryer Questions & Answers
3answers
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
2/21/2019 10:37:16 PM • Whirlpool... • Answered on Feb 21, 2019
7answers
Control lock
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
12/18/2018 11:44:06 AM • Whirlpool... • Answered on Dec 18, 2018
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at [email protected] with your name, phone number, address and the model and serial number for your dryer.
4/18/2017 2:41:23 PM • Whirlpool... • Answered on Apr 18, 2017
Where to find part
Try searspartsdirect.com They have all brands.
5/7/2015 6:40:59 PM • Whirlpool... • Answered on May 07, 2015
I have a GEW9250P ele dryer that the lights come on but it doesn't work.
-You heard the motor turn but the drum no turn>>> Broken belt or slip off. -It turn but no hot. Possibly the breaker is pop 1 leg. or control switch is dirty, burn contact. Good luck Mai Lor
11/14/2014 8:28:47 PM • Whirlpool... • Answered on Nov 14, 2014
2answers
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
7/16/2014 5:51:32 PM • Whirlpool... • Answered on Jul 16, 2014
0answers
The control panel lights up, When press start
Many problems can cause this. Call a technician.
9/27/2013 12:58:05 AM • Whirlpool... • Answered on Sep 27, 2013
manual
I have a Whirlpool Duet Dryer Model WED94HEXW0 and the end of cycle chime is not as loud as the matching washer, therefore, we cannot hear it when it is done. I have excellent hearing and don't u
you cannot make it any louder than it already is , Set a egg timer and keep it near by . sorry for the poor solution but there is nothing you can do
2/21/2013 1:09:52 AM • Whirlpool... • Answered on Feb 21, 2013
Lights are on but won't start
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing . If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
5/27/2012 5:21:12 PM • Whirlpool... • Answered on May 27, 2012
Control lock is on on my dryer and it will not
Press and Hold the end of cycle for 3 seconds. It will get unlocked
10/30/2011 3:09:42 AM • Whirlpool... • Answered on Oct 30, 2011
Whirlpool GEW9250P Electric Dryer Logo
110 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
control lock
  • Dryers
