Microsoft Office Professional 2007 Full Version for PC Logo
Jean Coyne Posted on Jan 20, 2010
Cannot download Document Imaging onto Microsoft
Microsoft Office does not come with Document Imaging. I have scanned a document and it comes up in a coded version and I want to decode it into English
. I have tried to download a document imaging programme but it does not work
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Jan 25, 2010
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
7443
Points
51
Okay go to google translator and copy and paste the code into the text box and translate it into english
1helpful
Is there a way to scan a document into my computer as a WORD document so that I can edit it?
  • Scan and save the file. Open that image and go to "File>Save As" and name it (filename).tiff. Go to "Start->Programs->Microsoft Office Tools->Microsoft Office Document Imaging". Go to "File->Open" and open your document. Go to "Tools->Send Text to Word."
  • When process is done Microsoft Word will start and your document will be present and able to be managed as you please.
  • 0helpful
    Scan document into text
    Scanned documents are image documents and they need to be converted using an OCR program. The Optical Character Recognition program converts scanned image documents into a text file which you can open with a Word program and edit.
    You need OCR programs such as -
    OmniPage 17
    ReadSoft
    GOCR (freeware)
    Tesseract OCR (freeware)
    Microsoft Office Document Imaging (included in MicroSoft office Tools)
    I have got a DCP-110C printer, how do I scan a document onto the computer then alter the text within this document?
    Try this procedure and let me know how it goes
    1. Scan the page you want to convert into a Microsoft Word document.
    2. Save the scanned image in *.gif, *.jpeg or whatever format.
    3. Open that image, go to "File->Save As" and name it "xyz.tiff" in the "TIFF" format as shown.
    4. Go to "Start->Programs->Microsoft Office Tools->Microsoft Office Document Imaging"
    5. Go to "File->Open" and open your scanned document that has been saved in *.TIFF format.
    6. Go to "Tools->Send Text to Word." You will get a prompt stating this process will take time, Click OK. This will take some time depending on your computer's speed (a minute or two at the most).
    7. When it's done it will open up Microsoft word on its own and the scanned document will now be in editable mode.
    1helpful
    Scan as Edit Text into Microsoft Word?
    Try Microsft Document Imaging. It's included in Microsoft Office Tools which you should find in the "Microsoft Office \ Microsoft Office Tools" folder in the start menu.
    I cannot print my documents even if there is Microsoft Office Document Imaging?
    hi,
    open Microsoft Office Document Imaging then opened the Tools menu, then
    Options. In the Options window, select the "Other" tab and clicked on the "Reset" button under Default Program.
    Then, close Microsoft Office Document Imaging and open windows explorer, navigated to an "*.MDI" file, right clicked it and chose "open with" "choose a program" then browse to the Microsoft Office Document Imaging executable found in the Office folder (don't remember the exact location) and select that executable to open *.MDI files and check the box "always use this program to open this file type".
    Now, finally, the "File" menu in Microsoft Office Document Imaging will work
    5helpful
    Scan multiple pages to email
    Do you have Microsoft Office?? If you do try this:
    First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
    You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
    Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
    • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
    Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
    Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
    • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
    • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
    • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
    • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
    • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
    • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
      • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
      • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
      To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
      1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
      2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
      3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
    Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
    3. Do one or more of the following:
      • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
      • To change the location for the saved files, click the Change button on the Output tab, and select a location.
      • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
      • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
    4. Click OK.
    Scan your pages
    1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
    2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
    3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
    Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
    1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
    2. In Document Imaging, click Open on the File menu.
    3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
    4. Repeat steps 2-3 until all of the files you need are open.
    You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
    • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
    • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
    • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
    For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
    The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
    Scanner not detected by Microsoft Office Document Scanning
    1) Install the Microsoft Office Document Imaging feature by following the steps
    given below:
    1) Go to Start -> Control Panel.
    2) Click the Add or Remove Programs.
    3) Select the Microsoft Office Professional Edition 2003 and click the Change
    button.
    4) Click the Add or Remove Features and click on Next.
    5) Select the Choose advanced customization of applications checkbox and click
    Next.
    6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
    and Indexing Service Filter.
    7) Select Run all from My Computer, insert the Office installation CD, and the
    feature is installed.
    2answers
    2007 won't scan to Word using HP Officejet Pro L7580
    unfortunately the following is from MS Word 2007 Help:
    The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
    After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
    Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
    Sorry.
    2helpful
    2answers
    Scan in word 2007 documents using vista
    From Word 2007 Help:
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
