20 Most Recent
Brother DCP-110C All-In-One InkJet Printer Questions & Answers
Red ink not printing!!!
To clean a print cartridge you should a glaas of water and 15-25 ml of alcohol and mix it in a small wide pan.
Dip the head (usually head is mounted to the cartridge itself) in the solution and move horizontally (while the head portion only submerged) keep it there for 5-10 minutes.
This should clean your print head.
After the head is dry you can mout it to the printer and print.
Caution: Do not touch the electronic contacts on spilt water or alcohol in it. This will damage the printer.
Looking for assistance
48 = head cable problem
lift top of machine as if changing ink, there is a black cover that needs to be removed to expose head cable, check it is pluged into board fully
remove A, check cables at B
Brother dcp-110c error 51
Try stamping your feet on the printer for 5 times, carry the printer up with ur master hand and smash it against the wall for 8 times. Make sure there is crack on the scanner cover. Last step, dump the whole thing into the nearest rubbish bin..
Replace ink
Take cartridges out of the printer, inside cartridge case if you look inside, in the back-middle part of it, you'll see black plastic. Take some swabs and wet them in alcohol, with it try to clean inside of the plastic.
Pict. is from DCP-J140 but PCB responsible for ink level recognition looks quasi the same. (Sorry for my English)
