It says i need to run device software ...i downloaded the auto installer program from u guys... but its not seeing the scanner still.. any suggestions?
For those folks who have Windows 7...
Click start from menu (bottom left of window pane),
Click "Devices and Printers",
Click on the HP printer listed,
Click "scan a document or picture"...
CALL IT DONE!!!! Gotta LOVE Windows 7...EASY!
1. Connect HP4215 to power and USB
2. Left mouse button click Start
3. Right mouse button click Computer
4. Left mouse button click Manage
5. Left mouse button click Device Manager
6. Left mouse button click "+" (plus sign) next to any HP devices including Imaging Devices
7. Right mouse click then left mouse click (for each device) Uninstall
8. Remove 4215 from USB
9. wait a moment and exit manage
10. reconnect USB and re-enter device manager
11. watch and wait for 4215 to reinstall itself (takes a minute)
12. Click on HP Director and scan documents and it 'should' open
HOW DO I SCAN WITH THIS HP 4215
I don't have a solution but I do have a problem. I have never used my scanner and I need to scan something for work. I am not sure how to do this. I see that you can insert the paper from the back side, I push scan but nothing happens. Can you tell me what I am doing wrong?
Solutuion 1-open the door for the print cart. close the door.
solution 2- change or switch the usb cable.
Please help
Mine will not work either
My HP4215 4 IN 1 WILL only print when installed by Vista. Can't seem to find appropriate driver.
will not copy, print, nothing. tells me to install or run device
printer scanner says need to install sannner software. i dont that software
I have the 4215 officejet all in one and the scanner does not work and hasnt worked for a long time. When I hit scanner it says to download software device. Help.
I've downloaded the software off the internet (though my printer has been working all along, except for the scan function). I've checked and the download did not include scan function.
Everything works but my scanner
My printer works but the scanner won't. It says I need to download the software. Any solutions? It was working before without a problem then I got a new compter system and now it won't scan.
when i press ok button on printer it says to install software for scanner but i can't seem to locate that software
