Emerson Threaded 1.5hp Fullrate 115/230v Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is making a load sound and there is a water leak from the inpeller housing
Pete
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Jan 20, 2010
Pete
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
53425
Points
210
You are describing a bad seal and bearings going bad in the motor. I would replace both.
I have a water leak after the water runs through the radiator and I believe the motor the water leaks
sounds like if its leaking from front of motor then it is your water pump thats bad but first make sure its not from a hose at the thermastat housing. hope this helps
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
2helpful
Water leaking from the dispenser on front load washing machine
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
My Air Mate MK190 compressor does not pump up preasure.
Check the pitcock valve to make sure it is closed. This valve is used to drain moisture in the tank and could be damaged or open. Make sure the safety valve is not stuck open (it is spring loaded and has a ring attached to it). Last is to check the tube connections from the tank to the compressor housing (be carefully, the tubes and housing could be hot). Do you hear any air leaks? You can use some dish soap and water to drip some on the hose fittings and valves to help see the air leaks. Other than that, it sounds like the motor connection or piston.
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Water leaking on floor from my front loader
it sounds like it's a prob from the water solenoid to the drum and/or the soap box there is a hose that runs between these items to get the water into the drum
2helpful
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Steve Pack
Steve Pack
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
