Cars & Trucks Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove the blower motor from a 1978 ford bronco full size truck?
Greg Bernett
Level 3:
  • Ford Master 2,993 Answers
  • Posted on Jan 19, 2010
Greg Bernett
Ford Master
Level 3:
Answers
2993
Questions
Helped
2783202
Points
13428
Deluxe Hi-Lo Heater
  1. Disconnect the battery cable, remove the carburetor air cleaner and partially drain the coolant system.
  2. Remove the heater hoses from the heater core.
  3. Remove the glove box liner and remove the register duct by pulling from the instrument panel register and releasing the clip at the plenum.
  4. Disconnect the right cowl outside air inlet vacuum hose from the outside/recirculating door vacuum motor.
  5. Remove the rear housing from under the instrument panel. Remove the outside air inlet duct from the rear housing (4 nuts and 1 bolt) and install one upper nut to retain heater housing-to-dash after rear housing is removed.
  6. Remove two screws retaining plenum-to-dash (above transmission tunnel) and two screws to heater housing and remove the plenum.
  7. Install a piece of protective tape on A-pillar inner cowl panel, at lower right corner of instrument panel.
  8. Remove the lower right instrument panel-to-A-pillar bolt to hold the panel in the rearward position.
  9. Remove the heater core (3 screws retaining 2 plates).
  10. Remove the temperature blend door (snaps off).
  11. Remove the temperature blend door arm support (2 screws) and pivot arm retainer (1 screw).
  12. Remove blower motor (2 screws) and remove blower wheel.
To install:
  1. Transfer blower to blower motor and panel assembly.
  2. Install door arm pivot retainer (1 screw) and door arm support (2 screws).
  3. Install the temperature blend door (snaps on).
  4. Install heater core.
  5. Install the plenum (4 screws).
  6. Connect blower wires.
  7. Remove heater housing upper retaining nut and install the heater outlet (4 nuts and 1 bolt). Position the air inlet duct.
  8. Connect the white vacuum hose to the outside/recirculating door vacuum motor.
  9. Reposition the instrument panel, install the retaining bolts and remove the protective tape at the A-pillar inner cowl panel, lower right corner of instrument panel.
  10. Install the right register duct assembly and install the glove box liner.
  11. Connect heater hoses to the heater core assembly.
  12. Fill cooling system, install the air cleaner and connect the battery cable to the battery.
  13. Check blower motor operation.
1989 ford bronco 4wd . Every s o often the yellow rear antilock lights comes on with red brake, replaced rear and sensor. What's the most common problem?
The most common problem?!?!?!
FORD!!!!!!!!!!!!!!!!!!!!!
Next time you have occasion to pull the instrument cluster. I suggest you remove that pesky bulb and be done with it! That "anti -lock" system was a joke anyway. Who puts "anti-lock" on the REAR??????????
They really didn't think this through did they!
Oh and just one more little pet peeve of mine.
ALL FULL SIZE BRONCOS ARE 4X4!!!!!!!!!!!!!
AND ALL FULL SIZE TOPS COME OFF TOO!!!!!!!
Anybody know how to remove and replace the heater core in a '77 Ford Bronco?
not easy. must be remove from inside engine area. if it has ac, system must be also removed. replace blower motor as well, being that is also hard to get to later.
1helpful
Need spark plug diagram for 93 Bronco
Hi there:
You have several engine sizes there:
1993 Ford Bronco Full Size 4.9 liter L6 VIN "Z"
1993 Ford Bronco Full Size 5.0 liter V-8 VIN "N"
1993 Ford Bronco Full Size 5.8 liter V-8 VIN "H"
Hope this hesl; remember to rating this answer.
95 full size bronco transfer case 4x4 shift motor froze put new one in now it wont shift right
My brother has a 94 Bronco, we had the same problem upon installation of the new transfer case motor. In our case, all we did was liberally coat all moving parts of the transfer case motor with grease.
Removing gas tank on 1996 ford full-size bronco
how do I check to see if im getting fuel. the truck wont start, it turns over good I just cant hear the fuel pump at all
1helpful
'95 Ford Bronco full size I dropped the rear
Normally when you take driveshaft off, you'll see a big nut in behind it, that attaches yolk to differential. Remove that big nut, and it should come out, but may need a puller. It's splined, and should be a bearing in housing,yolk.
5helpful
2answers
Firing order for 1989 full size ford bronco 302
13726548 #1 cyl is front pass side and count to back 1234 are on pass side.5678 are on driver side.# 5 being front
12helpful
Rear axle seal replacement 1994 ford bronco
It is fairly easy to do. remove rear wheels and brake drums, remove the differential cover, rotate the diff to access the diff pin bolt and remove, remove pin, push axles inward and remove c clips, slide out axles and replace seals. reverse procedure
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
