Asrock K7VM3 Motherboard Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
16227
Points
69
To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
jacobe more
Level 2:
Habit-Forming:
New Friend:
  • Expert 29 Answers
  • Posted on Apr 18, 2018
jacobe more
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
29
Questions
Helped
14327
Points
176
Are you receiving Windows 7 Error 5 while running the certain program? If yes then give a call at windows 7 technical support number to Fix Windows 7 Error 5 and get step by step advice through windows 7 tech support experts.
How to Fix Windows 7 Error 5 Dial 1 800 229 9186 Toll Free for Help
karan malhotra
Level 2:
Guru:
  • Expert 211 Answers
  • Posted on Jan 10, 2010
karan malhotra
Expert
Level 2:
Guru:
Answers
211
Questions
0
Helped
74503
Points
521
The dvd is curropt .. get ur self a fresh copy of a windows 7 iso and the try... it will work
2answers
My screen is blank and says manager cannot reboot
screen on what? Why can't people put enough info to answer a question? Are you talking about Windows, and the Windows "boot manager"?
here are some fixes to try:
(located here: https://neosmart.net/wiki/bootmgr-is-missing/) I recommend working from bottom up, and trying system restore...unless you have a boot CD/DVD ...in which case try startup repair first.
<Donna> https://everythingit.us
This repair method works if you have the Windows installation disc.
Here are the steps to fix the BOOTMGR error with an installation CD:
  1. Insert your Windows install CD
  2. Restart your computer and boot from the CD
  3. Press any key when you see the "Press any key to boot from CD or DVD" message
  4. Click Repair your computer after selecting your language, time and keyboard method
  5. Select the drive of your Windows installation and click Next. The standard drive is usually C:\
  6. Select Startup Repair
  7. Wait for the process to finish
Fix #3: Use bootrec.exe to rebuild the BCD
bootrec.exe is a tool built in the Windows Recovery Environment (Windows RE) that you can use to troubleshoot and repair the error.
bootrec.exe can repair boot configuration data and master boot records. BCD, which stands for Boot Configuration Data, contains boot configurations options and controls how Windows is started.
Here are the steps for accessing bootrec.exe to rebuild the master boot sector:
  1. Insert your Windows 7 or Vista install disc
  3. Press any key at the "Press any key to boot from CD or DVD" message
  4. Choose Repair your computer after you select the language, time and keyboard method
  5. Select your Windows installation drive (usually C:\)
  6. Click Next
  7. Select Command Prompt in the System Recovery Options box
  8. Write the following command and press Enter:bootrec /rebuildbcd
Fix #4: Run System Restore
The next solution will work only if you have System Restore enabled on your Windows.
Here are the steps for restoring your PC with System Restore:
  1. Insert the Windows 7 or Vista install disc
  2. Restart your computer and boot from the install disc
  3. Press a key when "Press any key to boot from CD or DVD" message appears on your screen
  4. Click on Repair your computer after selecting a language, time and keyboard method
  5. Select the drive where you installed Windows (usually C:\)
  6. Click Next
  7. Select System Restore from the System Recovery Options box
  8. Follow the System Restore wizard instructions to select a restore point
  9. Restore your PC by clicking Finish
Fix #5: Use bootrec.exe to fix the boot
The partition boot sector is stored on the hard disk drive and contains the necessary code to start the Windows boot process. If this partition is corrupt or not properly configured during a Windows install it would lead to "BOOTMGR is missing or corrupt" errors at startup.
This method needs a copy of your original Windows installation disc.
Here are the steps to fix this error using the bootrec.exe tool, the same tool used in Fix #4 above:
  2. Restart your computer and boot from the disc
  6. Click Next
  7. Select Command Prompt from the System Recovery Options box
  8. Write the following command and hit Enter: bootrec /fixboot
  9. Wait for this message to appear: The operation completed successfully.
  10. Restart your computer
HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
2answers
How do you install windows 7 on HP pavilian 754n? plz tell me quick because we just bought windows 7 and it doesnt work on the computer. thx you!
First you will need the Window 7 operating system cd.
place the cd in the cd room and let the auto run take place. this is not a quick process
it will take several minutes. If the operating system is not loading you may have a different problem
2helpful
2answers
I have a Motherboard MSI 865PE Neo3 MS-6728 ver3.0. You can install Win XP normally but is will never boot any Windows 7 CD installer with boot error "CDBOOT: Cannot boot from CD - Code:5". I...
be sure if you computer and the installer is the same as 32 or 64 bit.. check your computer and your installer.... be sure you have updated version of your motherboard..
My computer will boot an installation cd but not a dvd . I am using a asrock K7Vm3 motherboard. I also get a code 5 error
Code 5 error = Your pc is too old and the 7 install disk doesn't have even a basic driver for it.  Simply put your system isn't supported, 7 will not install easily , and if you manage to install it  it will run miserably slow.
2answers
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
Error 7 xp reboot
That's strange because that is how you install xp, from the operating system disk, maybe it is a bad disk, let me look up those errors, http://forums.techguy.org/hardware/620187-solved-cannot-boot-cd-code.html
check this out it's the same as you describe
3helpful
4answers
Compaq Presario Laptop ERROR CODES
it is a hard drive problem plz try with another hdd
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
