20 Most Recent
Asrock P4I45GV R5 Motherboard Questions & Answers
Problem regarding usb booting
the hard drive registered in the standard cmos utility is the only one that could be registered for boot in advanced cmos setup and no other, if your usb hard drive and pen drive could be registered in the advanced cmos setup - where boot options are registered, surely it will boot your pc.
uzowuanya
e-mail:
[email protected]
Hdd not detected
IF YOU MEAN IN COMPUTER HAVE YOU INITIALIZED THE HDD.GO TO ADMINISTRATORS TOOL-COMPUTER MANAGEMENT.-STORAGE -DISKMANAMENT (LOCAL).THERE SHOULD YOUR HDD BE INITIALIZE IT.
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
No display on monitor but cpu is running
The main problem is in the RAM or MEMORY CARD, just detach it and place it back or on another slot beside it.... if this dont work, buy a new memory card. but this usually works
