Master
- Posted on Jan 10, 2010
Re: PowerProduder wont recognise my blank DVD disk just...
Lets try refreshing your driver list.
Try this:
First uninstall power producer.
- Open Registry Editor:
- On Windows 2000 and XP: Choose Start > Run. Type regedit in the Open text box and click OK.
- On Windows Vista: Choose Start. Type regedit in the Search text box, and press Enter.
- In the left pane of Registry Editor, navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select
the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a
folder.
- Select File > Export (Windows XP and Vista)
- In the Export Registry File dialog box, select Selected Branch
under Export Range, name the file (for example, CDDVDkey.reg), and
click Save to save the file to the Desktop.
- In the right panel of the Registry Editor, select the LowerFilters
line, and then choose Edit > Delete. Click Yes in the Confirm Key
Delete dialog box.
- Select the UpperFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
- Close Registry Editor.
- Open Device Manager:
Choose Start > Control Panel. Double-click the System icon, click on
the Hardware Tab, then click on Device Manager.
- On Windows Vista: Choose Start > Control Panel, double-click System, then click Device Manager in the Tasks pane.
- Click on the plus symbol next to DVD/CD-ROM Drives.
- For each DVD-ROM or CD-ROM drive listed, select the icon then choose Action > Uninstall.
- Restart Windows.
- Windows will automatically detect and reinstall your DVD-ROM or
CD-ROM drives. You can verify that the drives are installed by viewing
them in Device Manager (see step 9). If the drives are not present,
open Device Manger and choose Actions > Scan For Hardware Changes.
Re-install power producer and see if the issue is resolved.
Sai.
