20 Most Recent LG GSA 4163B DVD±RW Dual Layer Burner Questions & Answers
Here is what I suggest. I would go ahead and upgrade your OS. Windows Vista actually has worse performance than Windows 7/8/10. I recommend installing via USB flash drive. https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool
If you really can't get your hands on an upgraded OS. Here is a link that might help you to resolve your problem: No CD Rom drive in Device Manager No error reported by XP Windows XP
Otherwise I think it might be a driver issue. If you could supply the product serial I could point you to some proper drivers.
LG GSA 4163B... | Answered on Jun 29, 2017
What a rude message.
The error correction is in the firmware of the player, not the type of disc.
Many people have similar issues due to DVD players expecting the TOC to be standard and not for a PC/Mac.
I agree that Nero should be able to sort this out but if all copies work on your PC but not successful on your DVD player would suggest to me a copyright issue.
LG GSA 4163B... | Answered on Feb 27, 2017
yes... but you need to have a good ammount of RAM memory and Disk drive space to achieve that since dual layer disc are up to 8 gigs..
LG GSA 4163B... | Answered on May 15, 2014
Check its optical pickup unit. Clean it. If it do not help you, replace it.
LG GSA 4163B... | Answered on May 02, 2012
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this does not fix the problem
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
LG GSA 4163B... | Answered on Jun 16, 2011
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question or exclamation mark ? ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
http://www.opendrivers.com/companydriver/2165/optiarc-free-driver-download.html
you will need to select your operating system
also
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
LG GSA 4163B... | Answered on Jun 11, 2011
you have not said what the problem is so ill take a guess
if your computer came with a motherboard disc the drivers could be on it
make sure that the cd rw is getting enough power test all leads that are attached to the cd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
LG GSA 4163B... | Answered on May 10, 2011
hi, your dvd is need to clean thats why he cannot read a data, you need to buy a cleaner disk for that. thanks
LG GSA 4163B... | Answered on Apr 29, 2011
Problem occurs when vista registry entry is corrupted. The steps to resolve this are as follows:
  • run regedit.exe
  • navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  • Depending on your particular setup, you may have multiple entries for {4D36E965-E325-11CE-BFC1-08002BE10318}. If this is the case, find the one that says DVD/CD-ROM drives (under default)
  • Once you have found the appropriate key, you will see an entry that says UpperFilters.
  • Delete this key and then restart
  • (NB: Do not delete any other 'UpperFilters' key that is not in the category of DVD/CD-ROM drives, otherwise you may get the BSOD.)
This solution fixed my problem.
LG GSA 4163B... | Answered on Jan 22, 2011
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters Upper Filters.bak
Lower Filters.bak
hope this helps
Sound like your lazer is weak to burn ok to read time to replace if burning is essental
LG GSA 4163B... | Answered on Jan 09, 2011
OKay
Sounds to me your trying to do what i did and did not work. the issue is the netbook is not compatable with this method you need a netbook compatable External unit is what i suggest, if there are any experts that have diffrent advice I welcome it as well. But I tryed what your doing in fact i went out and bought a external unit because of this fact, the issue is compatability.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
LG GSA 4163B... | Answered on Oct 12, 2010
Go to the page linked below and click ONLY on the Blue download arrow. All else is very confusing advertising. You may experience as much as 2 more pages to wend your way through but always stay focused on your downloadthe only. When you download it, the download window will appear. Choose "SAVE" , then 'Desktop" as the SAVE destination. Shut down all other programs. Double-click on the driver file (it's actually known as "firwnware" for DVD playeres). It is normal to be advised that your computer will be taken over and forcibly shut down at the end of the application.
If the firmware was what was needed, your DVD player will run fine.
Regards,
TheSelkie
LG GSA 4163B... | Answered on Oct 11, 2010
LG GSA 4163B DVD±RW Dual Layer Burner Logo
70 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GSA LG
  • GSA LG
Most Popular Question
hl dt st dvdram gsa 4163b ata when
  • Computers & Internet
