20 Most Recent
CyberLink PowerProducer 2 for PC Questions & Answers
Background music
On the main menu of power producer, click the tools or preferences icon/button. Then on the projects tab under the menu settings section reset the "User defined motion menu duration " to slightly longer than your music file duration.
Hope this helps
11/4/2018 7:19:39 PM •
CyberLink...
Answered
on Nov 04, 2018
Mpeg files have no sound when played in power
having same problem with Mpeg files have no sound when played in power producer gold. I notice that SW Synth, CD Audio and PC Speaker is always muted when capturing from Camcorder camera. Any suggestions. Also no sound when played with media player.
8/14/2010 7:35:05 PM •
CyberLink...
Answered
on Aug 14, 2010
I have been using Cyberlink
If recently you have made any hardware or software changes eliminate that and then check how it works.
Do system Restore to a previous date when your computer was working fine to do that go to Start - all programs - accesories - system tools - system restore select a date when your computer was working fine follow the on screen steps.
if you have win vista then start-search type system restore and do the same thing.
If this doesnt helps try to uninstall and reinstall the software.
7/25/2010 1:45:02 AM •
CyberLink...
Answered
on Jul 25, 2010
I keep getting message EOFF000C and it sometimes
it is a corrupted registry problem try a registry repai software if you have norton let it have a try, but i would check the registry and would ventre a guess that you have gotten a blue screen from time to time. its all in your registry it is corrupted.
Mel
6/5/2010 5:10:06 AM •
CyberLink...
Answered
on Jun 05, 2010
Hello, I am using cyberlink
Use the DOS copy command to append a bunch of MP3 files together, and then use the one combined file. It works best if the MP3 files all have the same characteristics (volume, bit rate, etc.)
In the command prompt, go "copy /b one.mp3+two.mp3+three.mp3 combined.mp3"
4/3/2010 2:24:36 AM •
CyberLink...
Answered
on Apr 03, 2010
When I edit and burn a dvd using Powerproducer 3,
Actually some of the software needs an update . just update it or it might not be compatible to your pc. it also did the same problem with nero on my pc . it plays the video but there was no audio. simple use another software
3/17/2010 6:23:41 AM •
CyberLink...
Answered
on Mar 17, 2010
PowerProduder wont recognise my blank
Lets try refreshing your driver list.
Try this:
First uninstall power producer.
- Open Registry Editor:
- On Windows 2000 and XP: Choose Start > Run. Type regedit in the Open text box and click OK.
- On Windows Vista: Choose Start. Type regedit in the Search text box, and press Enter.
- In the left pane of Registry Editor, navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select
the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a
folder.
- Select File > Export (Windows XP and Vista)
- In the Export Registry File dialog box, select Selected Branch
under Export Range, name the file (for example, CDDVDkey.reg), and
click Save to save the file to the Desktop.
- In the right panel of the Registry Editor, select the LowerFilters
line, and then choose Edit > Delete. Click Yes in the Confirm Key
Delete dialog box.
- Select the UpperFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
- Close Registry Editor.
- Open Device Manager:
Choose Start > Control Panel. Double-click the System icon, click on
the Hardware Tab, then click on Device Manager.
- On Windows Vista: Choose Start > Control Panel, double-click System, then click Device Manager in the Tasks pane.
- Click on the plus symbol next to DVD/CD-ROM Drives.
- For each DVD-ROM or CD-ROM drive listed, select the icon then choose Action > Uninstall.
- Restart Windows.
- Windows will automatically detect and reinstall your DVD-ROM or
CD-ROM drives. You can verify that the drives are installed by viewing
them in Device Manager (see step 9). If the drives are not present,
open Device Manger and choose Actions > Scan For Hardware Changes.
Re-install power producer and see if the issue is resolved.
Sai.
1/10/2010 4:19:20 PM •
CyberLink...
Answered
on Jan 10, 2010
I keep trying to upload
two things,,
You may not have enough disk space on your computer to hold the data,, and 70% just happens to be how much free space you have.
Check your comptuer see how much empty space you have on your hard drive. if you dont have much try freeing up some space.
If that dont work, you may have to try reinstalling or repairing your software. Just uninstall it, then reinstall it.
This should fix any other issues.
These are the two main solutions to your problem.
If this was helpful please mark it fixya.
1/10/2010 2:59:58 AM •
CyberLink...
Answered
on Jan 10, 2010
Cannot use with windows 7
try right clicking on the power producer gold 2 install file and click properties , then click on the compatability tab then select run in compatability mode for windows xp sp3.
That will allow you to install it , if it runs or not i am not sure, but worth a try.
If you right click on the shortcut file on your desktop pp gold 2 you can also set that for windows xp sp3 compatability too
12/29/2009 5:18:52 PM •
CyberLink...
Answered
on Dec 29, 2009
