Posted on Aug 24, 2017
Distortion from Jamo D4 - problem cone?
I have some D4's powerd by an Onkyo amp, and this is a speaker problem is giving distortion whilst the other is perfect. Cones are were replaced a few years ago and there is no visible signs of wear. When standing and pushing cone it feels as if the one that is giving distortion is rubbing. What is the solution - another new 10", if so from where should this be purchased.
Thanks
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on Jan 04, 2008
SOURCE: distorted audio
I think the volume increasing or decreasing of you woffer box has been got damaged please change your button as quickly as possible...
Thank you..
David Shaub
  • 2994 Answers
  • Posted on Feb 02, 2009
SOURCE: Jamo i300 speakers are dead.
There is peobably a fuse located on the back. Your speaekers are probably okay. If anything fried inside, it is probably the output transistors.
John Weinreich
  • 336 Answers
  • Posted on Mar 08, 2009
SOURCE: The foam edge support for
Check out this site: http://www.mcmelectronics.com/search.aspx?C=&K=speaker%20repair
or google search "speaker refoaming" to find a local or somewhere to ship them to be repaired.
Jeff3fg
  • 124 Answers
  • Posted on Mar 21, 2009
SOURCE: CLARION MARINE SPEAKERS CONE DETERIORATED
of course, the only problem is finding someone to do it, and is the speaker really that nice and worth the money
denonjapan
Leo Joaquin Dela Cruz
  • 58 Answers
  • Posted on May 08, 2009
SOURCE: Distortion noise from the 5 speakers and a sub
rattling noise comes from your wiring color coding. make sure positive goes into positive, negative to negative. You may have connected the output into the output of the sub. and satellites are in the input.
For a 12 inch 4 Ohm DVC with 1200 Watts Max/400 Watts Nominal what size amp should I be using?
The speaker info is telling you that a 400watt input is nominal or stable. and handle anything that can Peak up to 1200watt , the speaker can handle the 1200watt but not for long periods. Distortion will likely occur well before then anyway. On my home stereo, I have twin Marshalls which are 500 watt each going to JBL,s rated at 150 watt with 250 peak. The ratings are a bit different from manufacturer to manufacturer. Ive found the system is really powerful but there is very little to no distortion as the amp is not needed to be cranked up to get the volume I want. If you run an amp that is too big for the speakers, it will sound really loud for a while, then distortion happens then watch your speaker cones self destruct or the voice coils burn out. If you run an amp that is too small, you will need to turn it up more for the volume and then distortion sets in earlier, which is the biggest destroyer of any speaker.
Kicker solo baric l7 12" has distortion at low volume. What could cause this?
It sounds like the cone is distorted. If it's a paper cone, it may have gotten wet. If it's a poly cone, it may have been exposed to too much heat (sunlight?).
Also check the wiring; anything loose may make a rattling sound.
Last, the problem may not be in the speaker at all - it may be a problem with the amp.
2answers
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
2answers
My jamo d115 speaker tweeter distorts or rattels when any serious bass kicks in, how do you stop this?w
Possible this is a distortion from the Amplifier if the speakers are not damaged. however it is important to switch the speakers to confirm if the fault is relative to the particular channel in which case the amplifier is faulty. If not the speaker can be the culprit. All what is needed is to reduce the BASS level a bit lower when the volume is increased so as to allow the cross over to work. Also if teh cross- over network is faulty within the speaker the bass can vibrate on the tweeter.
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
I have Behringer 1c monitor speakers. My amplifier is Yamaha 8 0hm, 75 watts per channel. How do I connect the 4 ohm speakers to 8 ohm apmlifier.
This is a problem I have had as well. Know that Yamaha and other manufacturers that give an 8 ohm minimum spec DO NOT reccomend hooking 4 ohm speakers up to their amplifiers. That being said, I have had no problems with the Behringer 1C on Onkyo, Sony and JVC amps. You *must* be careful to regulate your listening volume, and be aware that the distortion the amp produces into a 4 ohm load is much higher than with 8 ohms. You also take the risk of cooking your output transistors.
It is up to you to decide if the risk, the neccessary self imposed volume limiting and the added distortion are worth it.
My subwoofers cone keeps detaching why is this
Your amp is too much, or your gains and bass boost are set too high and the sub is distorting. Distortion happens when any of those three things are happening, basically your sub is no longer moving straight in and out and the cone is trying to compensate. This causes the cone to break away from the coil.
Hi, this is not really a problem. I have an Onkyo TX-SR604 receiver. I had polkaudio speakers RTi8 speakers that are no longer working properly. I am looking for recommendations for new speakers that can...
A receiver with the specs...
* "90 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08%"
(*) The only acceptable statement of its power bandwidth in the manual.
... when fed an undistorted audio signal, used properly and not driven abto clipping is not particularly dangerous to any reputable speaker.
Driving any amplifier, even a modest one, into high distortion is more dangerous to any speaker than a high-powered amp pumping pure undistorted power.
Choose any speakers but low efficiency models if you want loud and clean sound.
1helpful
Quad 11L One of my speakers seems to distort the sound for a minute or two on switching on the system and then starts functioning normally again. I have a feeling that my toddler may have twiddled the...
First, swap the speakers to see if it stays with the speaker or the amp channel.
Second, disregard the throretical ability of any speaker to handle any amplifier's maximum output. Amp ratings are at a certain power output with a certain amount of distortion. Turn the volume a click higher and power output might rise just a tad but distortion starts to go ballistic. Continue and you get total high current garbage. Clipping (high DC output) will kill any speaker.
Since it seems to go away, I doubt the speaker is damaged, unless torn speaker cone or burnt voice coil can self-repair in a few minutes every time.
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
