20 Most Recent
Phoenix Gold Xenon X10D4 - 10" D4 Subwoofer 450/800 Watts Car Speaker Questions & Answers
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
How to hook up led lights for phoenix gold x10d4
THERE ARE 2 WAYS:
1. (STEADY ON) - RUN THE POWER FROM THE AMP TO THE POSITIVE LED TERMINAL THE NEGATIVE CAN BE RAN FROM THE NEGATIVE SPEAKER TERMINAL.
2. (INTERMITTENT; COMES ONE EVERY TIME THE BASS HITS) - RUN THE POSITIVE AND NEGATIVE WIRES FROM THE + AND - TERMINALS TO THE POSITIVE AND NEGATIVE TERMINALS OF THE LED LIGHTS.
LET ME KNOW IF THIS WORKS FOR YOU --
[email protected]
My phoenix gold iron not heating up all blue lights flashing "need help please "
If your Phoenix Gold iron is not heating up and all the blue lights are flashing, it indicates a potential issue with the iron. Here are some troubleshooting steps you can try:
1. Check the power supply: Ensure that the iron is properly connected to a functioning power outlet. Make sure the power cord is securely plugged in and that there are no loose connections.
2. Allow the iron to cool down: If you have been using the iron continuously for an extended period, it may have reached its temperature limit and shut off for safety reasons. Let the iron cool down for a few minutes and then try turning it on again.
3. Clean the iron's soleplate: Over time, the soleplate can accumulate dirt, residue, or fabric fibers, which can affect the iron's heating performance. Make sure the iron is unplugged and cooled down before cleaning the soleplate. Use a damp cloth or sponge to gently wipe the soleplate and remove any debris. Avoid using abrasive materials that could scratch the surface.
4. Check the water tank: If your iron has a steam function, ensure that there is sufficient water in the tank. If the water level is low, refill the tank according to the manufacturer's instructions. A low water level can prevent the iron from heating properly.
5. Perform a reset: Some irons have a reset button or a combination of buttons that can be pressed to reset the device. Consult the user manual for your specific model to find out if it has a reset function and how to perform it.
6. Contact customer support: If the above steps do not resolve the issue, it is recommended to contact the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or advise on repairs or warranty options if necessary.
Always refer to the user manual provided with your Phoenix Gold iron for model-specific instructions and safety guidelines.
