Toshiba Satellite A100-S8111TD Notebook Logo
Anonymous Posted on Feb 01, 2008
Ask pare, nainetwork ko na ung 7 pc. e pg lan games pano? pg nainstall ko na games 4 example counterstrike. mgcconect n b un lhat? salamat pare.
  • Anonymous Feb 03, 2008
    ok lng melnavz.
    salamat senyo mga pre.
Anonymous
Level 1:
Problem Solver:
  • Contributor 42 Answers
  • Posted on Feb 01, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
42
Questions
5
Helped
8312
Points
68
Keanne...
yap magcoconect na lahat iyong pre, pero pag ayaw try mo i-off ung firewall...siguraduhin mong may antivirus ka muna ok?
Anonymous
Level 3:
Genius:
  • Master 1,226 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1226
Questions
Helped
622429
Points
3211
Pare wala wala akong alam sa games, Pero siguro , kailangan lahat na pc ay nandoon ang games files , siguro kung sino yong mauuna ang ang siyang maging server, at ang lahat ay magkonect doon. Eto pare pag network games na, at pag di mag connect siguro kailangan static Ip address. sorry pare ha hindi pa ako nag explore ng games.
2answers
Guys..need help...bumili ako ng CDR-KING ROUTER CW-8196..nadedetect ko ung wifi signal pero walang internet access. pero pag direkta sa LAN ung net ko.malakas naman net ko..windows 7 gamit ko...
DUDE..simple lang yan...if meron ka modem...off mo muna modem..
tapos..un-install mo yung "ETHERNET ADAPTER"
den...from Modem connect mo to CDR-king Router - PC, tapos " restart "
and MAGIC...OK na NET MO..pati WIFI...
Ng ha2ng kc ung laptop ko. pg inoopen ko xa mya2 dko na mpindot ung mga application khit ung sa start... tpos ndi dn lmlbas ung sa tbi na prng bnubuklat.. i hope m2lungan nyo ko
There are 3 common causes why a computer hangs or locks up.
1. Overheating - kapag nag-oover heat ang cumputer, naghahang ung computer, or ung processor.
2. Incompatible or corrupted device driver or system file
3. Faulty RAM (Random Access Memory)
Para macheck mo kung related sa overheating ung unit, punta ka sa BIOS setup (either pressing F2, Del, F10.. just after ng manufacturer's logo..depende sa brand ng computer). Pag naghang siya sa BIOS, pacheck mo nalang sa computer technician due to motherboard/cpu issue. Pwede mo rin pacheck baka loose connection ng RAM mo, or faulty at kelangan na palitan.
For incompatible or corrupted driver or system file naman, reinstall mo lang ung driver (usually graphics driver ang cause ng freezing) or reinstall mo ung operating system (xp, vista, 7 or linux)
Hope this helps.
2answers
Paano mapabilis ang hatak ng motor ko? honda wavw 100 xa
may 155 tmx ako paano magiging high speed or 5 speed or 6 speed ang transmission ko ko
1helpful
2answers
Na virus un asus 701 laptop ko. pina format ko pero ayaw gumana un LAN at un wireless internet connections
HI...
MAG-DOWNLOAD KA NG DRIVER SA LAPTOP MO. IT'S THE ONLY WAY SEARCH MO "ASUS 701 DRIVER DOWNLOAD" SA SEARCH ENGINES...
GOODLUCK!!!
1helpful
2answers
Ayaw po mag open nokia 3650
gandang gabi sir! ulitin mo lang ginawa mo pero tagalan mo pag hold sa tatlong key nya at pati na rin po sa power switch dapat di mo agad sya bitawan hangat wala lumalabas na formating pero paalala lang po mawawala lahat ng naka save sa phone memory mo ha ! huwag po kalimutan alisin memory at sim card before mag format !
Sep 10, 2008 • Nokia 3650
Question
Appreciate the direct "Ask Me".
Yung Hello Kitty, Google pa rin plus konting scripts pang SEO (Search Engine Optimization).
Ang ibig mo bang sabihin na "may charge sa casing" eh may ground pa rin, if yes, then either galing monitor kung hiwalay power cord or dumadaan sa LAN cable;
If on the other hand, may ilaw pa rin sa LED on the motherboard, then residual power from the capacitor/power supply.
Or baka hindi ko lang masyadong naintindihan query mo.
Cheers.
Pano mgnetwork?
gud pm keanne...hmmm here's my suggestion:
1st u need to buy 8-Port Hub/Switch
NIC or LAN Card
7 pcs UTP Wire w/ RJ45 Jack on both end (depende sa haba)
Then connect smartbro to the CPU (Built-in LAN)
Connect 8-Port Hub/Switch to the CPU (LAN Card)
Install Hub/Switch Driver (If Needed)
Connect the 6 PC to the Hub/Switch
Setup your network using Network Wizard (Control Panel)
goodluck...
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
