Everytime I connect to an unsecured wireless connection my laptop said WLAN connection failed
This many not help because we were trying to connect to our home network which is secure and it kept failing. We finally found if we went into the Manage Wireless Networks and double-clicked on the network name to bring up properties and then went to the security tab and found that the security type was set to open instead of shared. We set this to shared and then it worked. Check yours and if it is set to shared maybe you need to set it to open to get it to work with unsecure networks.
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
hoyagese34
3. In the "Network and Internet Connections" window, click on "Network Connections."
4. Once in Network Connections, right-click on the wireless connection then select "View available wireless networks"
5. If the wireless network is a secured network, please refer to the
manual of the wireless router to make it unsecured for the purpose of
testing the wireless network.
NOTE: Acer does not recommend leaving a wireless network
unsecured and is not responsible for data accessed due to unsecured
wireless networks.
6. If the wireless network is listed, the wireless adapter is
functioning properly. If unable to connect to the wireless router, go
through "Before you start" at the beginning of this article.
