Hi ARADAM,
you don’t
provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift'
mixer, which would helpful, but you can easily download a PDF version of your
Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click
on Customer Care>Locate Manuals& Guides> and enter the 6
character model number and select a file listed under Owners Manuals and
save that file to your PC. You’ll need to have Adobe Reader to be able to open
it. Turn to Page 11 and you will find the instructions for adjusting the mixer
head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the
bottom of the bowl. If for any reason, the flat beater hits the bottom of the
bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or
clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.the flat coated beater has worn off the coating - eda6563.jpgsrc="/uploads/images/eda6563.jpg" alt="eda6563.jpg" class="h_mi" />
Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now
you’ll need
I hope this helps!
–Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
