SOURCE: Formatting and Partioning WD My Book for Mac OS X
what are the tips of hard disk drive troubleshooting
SOURCE: western digital 250gb my book external makes a clicking noise
100% faulty, 100% non repairable
SOURCE: I cannot retrieve my files from the wd 250gb
First instinct is that your drive has failed. I would remove the drive and insert it into a system to test. If it works, then it is the housing from the external drive that failed. If the drive does not work once inside your system, then the drive is bad. Good luck.
SOURCE: Mac not recognizing External Western Digital HD.
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
SOURCE: Western Digital Hard Drive will no longer mount
HI. So I had this problem twice with the same hard drive. I didn't have the money to replace the hard drive the first time, but this time I did, so my ultimate solution to offer is to purchase a different HD and migrate the data from the current one.
How did I get the drive to turn back on so I could get the data migrated to the new HD? Persistence! I kept disconnecting and reconnecting the drive, making sure to shut the drive down by pressing the blue button on the front until the drive powered down. I disconnected, waited for some time (between ten and 20 minutes) Then I reconnected the FireWire cable first, and the power cable second, waited for it to mount - and eventually...
IT DID!!
Wow am I happy.
I'm going to run a series of diagnostics on this one but I'm probably going to retire it. Too bad because 500 gigs is a lot of space to loose, but this being the second occurrence makes parting all the easier. I mean, my entire iTunes library is on this thing!
So, just keep trying - plug the drive into the computer, then connect the power cable and wait for it to come on.
I'm running Mac OS 10.6.4 and an older machine 10.4.11, both of which were able to read this drive before, the 10.6.4 had the problem initially, then both machines had issues. Ultimately the 10.6 machine was successful with a FireWire 400 connection.
I hope this helps!!
5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
