Bascially I am unable to set the time and date on a vestal G5 global traveler watch. Any help would be great.
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
I found the manual. If you want to reset the time: Hold el/set (light) for 2 seconds to enter real time setting mode. Press mode key to change to next setting item. Press st/sp or reset keys to increase or decrease the setting value. If el/set is pressed, it exits to real time display mode. Hope this helps. It will make sense once you enter the mode.
Just hold the light button for 3 seconds then you'll know what to do believe me, i had the same problem...
Same problem...
same problem here...
same again goin crazy tryin'to set time and date ....hhhhhheeeeellllppp
I have Vestal Crusader. I can't set the time. I understand to hold down the light button for three seconds, but then I still can't figure out the way to go from hours to minutes. I must be stupid! Any help is appreciated.
same prob
Unable to Set the time and Date on my Timex Digital Expedition Watch
