My zenith lcd tv has lost its blue tint. Most everything has a green tint to it. I've tried adjusting it with the tv remote but with no success. Are there 'codes' to fix this problem? Any solutions out there?
The light polarizer on the blue lcd panel is fried due to excesive dust and heat, and therefore need to be replaced. unfortunately, zenith may not sell individual parts of the optical engine, so you'll have to replace the whole optical engine.
there
are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode
might not working in your set that is why you have a green screen. Open
the back cover of your TV you can immediately see the 3 cathode lamp at
the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is
connected re-solder all the components in this lamp. There is also an
individual screen adjustment for the lamps it is located at the front
panel and labeled RGB screen...try this first and let me know how it
goes..
Hi Thanks for using FixYa. Usually
this happens when the Light Engine has gone bad, and I should say this is a
common issue with Projection TVs. There are three tubes/mini LCDs inside your
TV- green/yellow, blue and red. When the set heats up over time of usage the
screens tend to break resulting in leaking color everywhere. The cost to get
this fixed by a professional should be around $300 depending on the parts that
needs to be replaced. Please do accept the
solution if the issue is resolved or else revert for further assistance. Thanks Rylee
I have Zenith D.V.D V.C. R. Recorders The v.c.r. is working the D.V.D. I put Memorex D.V.D read no D.V.D i put Sony D.V.D REAd no D.V.D i like why no working The model no XBR 716 120-60 hz 24w Service no X br716 Ul File no E 225515
The core problem with the green tint is the aging of the picture tube, and can be compensated a bit by using either the green drive control usually located on a printed circuit board on the neck of the picture tube or on the main chassis. There will be 3 main controls which will adjust the red and blue as well. If these controls are not present then you will need to get into the service menu and adjust it from there. Don't adjust anything else as you can make the set much worse. Also remember that in order to make these internal adjustments while watching a black and white picture (turn the color all the way down) you will have your hands and arms near live circuits that could shock you and cause injury to yourself as well as break parts inside the set when you pull back after being zapped (voice of experience here) Of course if you can do all this by the service menu then you won't even have to remove the back of the TV.
