How to Start
To enable file sharing, do the following:
To enable public folder sharing, do the following:
More
Windows Firewall
To share a drive
Now what are these settings??? They are Sharing permissions...
But what about NTFS permissions??? That is where the problem occurs
So you have to adjust them also...
Make sure you have ntfs format in the hard drive.
Note: You can use password protected sharing in Vista for a higher level of security
Note: Sharing via the Public folder is quick and easy but inflexible.
Note: If you select Everyone,
and you have password-protected sharing enabled, the user must still
have a valid account on your computer.However, if you have turned off
password-protected sharing, network users can gain access only if you
grant permission to Everyone or to Guest.
So we will do this in an advanced way...
Here is how
To make sure the Sharing Wizard is enabled, click the Start button, type “folder” in the Search box, and then click Folder Options. Click the View tab. In the Advanced settings box, scroll down the list and un-tick the Use Sharing Wizard (Recommended) check box is selected.
This will set all the necessary things. Then you are set to go.
Use advanced settings to create or modify a network share
If this solution is helpful to you please rate the answer.
Thank You for contacting Fixya. :)
Hi
make sure the client computer you have logged into is been logged in with administrator rights.
Hope this solves the issue, if not revert back.
