20 Most Recent
Creative Labs Sound Blaster Live! 24-bit External External Sound System Questions & Answers
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Driver for Sound Blaster 24bit live on windows XP wanted
http://ccftp.creative.com/manualdn/Drivers/AVP/10003/0x39A4F4C3/USBVS_PCDRV_LB_1_00_0060.exe
Try that link
Driver for :
OS: Windows XP,Windows NT SP3,Windows NT SP1,Windows 3.11,Windows 2000 SP3,Windows 2000 SP4,Windows 95,Windows NT SP2,Windows ME,DOS,Windows 98 SE,Windows NT,Windows 98,Windows 2000 SP1
Good luck
Does all the features from soundcard work on
im not sure what you are referring toclick start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality
How much?\creative labs usb sound blaster live 24
hi i have now offic7 and when i instsll my creative sound card no.580490 throw my oregnal cd. some part of program did'nt work like amixer etc.and alaway's i got this not on my computer . thes deveic not deteceted ?\r\npleas help me
I just install a quad core processor, and the
Is it just a replacement of a defective one? If it is, then, you still have the same operating system in it. Put your PC on, and left click, Setting, Control Panel, Systems, Hardware, and finally the Device Manager. You will now see the installed devices/hardware in
your PC. Right click over the sound, audio devices,
and view the status and property of this item. You
will be prompted on what to do next. If you don't get
results, your option is to reinstall the software driver.
If you have the CD for sound/audio software driver,
insert the disc and install the driver. If this is not
available, you can connect to the internet Just type at the search engine blank (Free download for sound/audio software driver) and click over it. Then, follow the instruction for you to get the free download.
the sound/audio software driver download
I lost the original instalation disk for sound
Creative lists this driver : http://support.creative.com/Downloads/welcome.aspx
If that dosen't work you could try the auto update here: http://support.creative.com/downloads/SoftwareAutoUpdate.aspx?AID=5902012&PID=2777698
Good luck
Same issue...but only on vista...
If it were me, I would find out if 'ALL' of the drivers are available for XP. If they are, I would then downgrade to XP. I would also let Creative know about the performance problem. They may be able to fix it.
Creative sound blaster live 24 bit soundcard external usb
Explanaition:
This delay you are experiencing is called latency. All equipment or signal processing unit introduces some latency even if extremely low.
Computer tends to be a lot worse than outboard gear.
Solution:
Look for Asio4All, this little driver will help you improve your audio input latency. And remember, the smaller the buffer size the lower latency you get.
http://www.asio4all.com/
