When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
This may be helpful...
http://bargainbox.com.au/search.php?sear...
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light.
https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
Back light EL panels and cutoffs at a very affordable economic price can be found at the following link: http://www.backlight4you.com/index.php/cat/c46_EL-Panels.html
You can have them precut to your exact dimensions or order a larger sheet and cut to size. Good luck.
https://sew-bright.com/products/janome-m...
