Northstar Pressure Washer Turbo Nozzle Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant figure out how to repair my turbo nozzle how do you take apart the nozzle.
Roland W VanLue
Level 3:
  • Master 486 Answers
  • Posted on Dec 04, 2009
Roland W VanLue
Master
Level 3:
Answers
486
Questions
0
Helped
315221
Points
1454
Most commonly, debris gets plugged internally in the nozzle holes. Using a small pick from the outside, with the nozzle removed from the wand (it is threaded on), you can try to dislodge debris caught in the nozzle holes.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Turbo Blue Torch Repair
Here are the steps to reassemble a Turbo Blue Torch Lighter:
  1. Collect the parts: Gather all the parts of the Turbo Blue Torch Lighter that you have disassembled. These typically include the top cap, the burner nozzle, the burner assembly, and the ignition mechanism.
  2. Reassemble the burner assembly: Start by reassembling the burner assembly. Place the nozzle back onto the burner assembly and screw it in place. Then, slide the burner assembly back into the top cap, ensuring that it is seated securely.
  3. Reattach the ignition mechanism: Take the ignition mechanism and insert it back into the top cap. Align the ignition mechanism with the burner assembly so that the sparking mechanism is facing the nozzle.
  4. Reattach the top cap: Place the top cap back onto the base of the lighter and screw it in place. Make sure it is tightened securely.
  5. Test the lighter: Once you have reassembled the Turbo Blue Torch Lighter, test it to make sure it is working properly. Hold the lighter in your hand and press down on the ignition button. The lighter should ignite with a blue flame.
If you have any difficulties or concerns during the reassembly process, consult the manufacturer's instructions or contact their customer support for assistance. It's important to reassemble the Turbo Blue Torch Lighter properly to ensure its safe and efficient operation.
2answers
Why does my pressure hose burst when I use a turbo nozzle
Turbo heads are pressure rated for different pressure washers, your turbo head is most likely rated bellow the maximum pressure of your washer which in turn causes a pressure build up in the hose and it's eventual failure.
How do I get the motor out of the power nozzle on the E-series?
The eSERIES Rainbow has several versions of the power nozzle. Some screw apart and others have snap connections. Look at our website on the manuals page to determine your model. You can also call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
1helpful
Can my EGR , couse black smoke when i aply the trotle and some times trys to stall outand i get a loud clacking like ny lifters are not getting oil to them , This is on deisel 6.5 turbo.
BLACK SMOKE SIGN YOU NEED TO CHANGE AIR FILTER,BUT CLATTERING NOISE COULD BE THE INJECTION NOZZLES CLOGGED OR DEFECTED. YOU COULD ALSO HAVE BLOCKED FUEL LINE OR CLOGGED FUEL FILTER. FAULTY INJECTIONS NOZZLES HAS TO BE REPLACED CANT TAKE APART CLEAN THEM.
Im trying to connect my ps3 through my laptop with a telstra turbo usb dongle modem, i cant figure it out
better u download the repair guide to solve your problem easily.. click here to download the repair guide of ps3..
2helpful
Does the turbo nozzel come apart to repair?
Hi, yes, the turbo nozzle can be broken down with just a little time and effort. The two plastic wheels in the rear pop out, and then you'll see 6 screws on the bottom of the unit. Once these have been removed, gently pry the top and bottom pieces of the turbo nozzle apart, and you'll have access to the belt, gears, and brush inside. Good luck!
If this solution was helpful, please consider rating it. Thank you!
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
5helpful
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
2answers
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541327
Generic problem for all Vacuums
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: www.turbobrush.com – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 • Vacuums
Top Northstar Garden Experts
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Northstar Garden Expert? Answer questions, earn points and help others
