20 Most Recent Northstar Pressure Washer 3000 PSI Questions & Answers
Sounds like the trigger is not closing, best to strip it down and check operation. Probably siezed in the open position.
Northstar... | Answered on Oct 15, 2017
Cannot. Ensure u have a 3000psi wand.
Northstar... | Answered on May 17, 2016
If it connect to the outlet pipe/lance then it operates on SUCTION similar to blowing across the top of a beer bottle to make a noise. If thats the case it is a matter of blockage and ventilation of the soap bottle to allow air to enter as the soap is sucked out by the water flow.
Northstar... | Answered on Nov 05, 2015
you need to keep the gun open so allowed water to flow and not overpressure the pump.
Northstar... | Answered on Aug 16, 2015
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Northstar... | Answered on Mar 23, 2015
NGK bp4es
Northstar... | Answered on Dec 28, 2013
Northstar Pressure Washer 3000 PSI Logo
110 questions posted
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
View Most Popular
Northstar Garden
  • Northstar Garden
Most Popular Question
engine will not run
  • Garden
