20 Most Recent
Northstar Pressure Washer Turbo Nozzle Questions & Answers
Can't unscrew nozzle from hose what do I do to
I used a vise and pipe wrench to loosen. Have to be careful with the vise that you don't over tighten it and damage the hose fitting. When replacing the nozzle, lube the threads with non-water soluble grease.
8/29/2010 8:20:18 PM •
Northstar...
Answered
on Aug 29, 2010
My Northstar Turbo nozzle emits a solid stream of
NorthStar Pressure Washer Turbo Nozzle --> -->
Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
10/19/2009 6:33:45 PM •
Northstar...
Answered
on Oct 19, 2009
Water leak
bypass valve is shot or stuck in the "open" position
6/15/2009 6:24:15 PM •
Northstar...
Answered
on Jun 15, 2009
Burner will not fire
Dear muttandjeff,
I do not know if you machine is single or three phase. But whatever, one simple thing is to check that you have the right rotation. If the rotation is good, then fuel can be pumped. Now there must be a sensor that switches on with water flow. No water....no fire. If there is water passing, then the sensor is stuck and showing that there is no flow. The thermostat also opens a solinoid valve in most machines of this type. If solinoid valve is faulty....fuel will not come out. If this is a diesel boiler...check gap of electrodes and condotion of fuel nozzel. One last thing, is something I found in a machine of a friend of mine. I found everything correct....but then I found that the fuel was totaly mixed with water. So, that you have correct fuel, is also important.
fulltech.
12/18/2008 2:17:27 AM •
Northstar...
Answered
on Dec 18, 2008
Rats got into the heating
Any of the companies listed below can help you and are located in your area. These are all trained and certified service centers that specialize in pressure washer repair among other things.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
INNOVATIVE CLEANING SYSTEMS (ICS)
8724 WEST MALBORO ROAD
FARMVILLE, NC 27828 UNITED STATES
(252) 521-4291
CTS CLEANING SYSTEMS,INC
2185 ANGELIA M. STREET
FAYETTEVILLE, NC 28312-8398 UNITED STATES
(910) 483-5349
CSC INDUSTRIAL SALES & SERVICE LLC
600 - D UNION WEST BLVD
MATTHEWS, NC 28104 UNITED STATES
(704) 684-0223
MVP SERVICES, INC.
5813 A. TRIANGLE DRIVE
RALEIGH, NC 27617 UNITED STATES
(919) 788-0267
CLEANING SYSTEMS OF THE TRIAD
5610 RANDLEMAN RD.
RANDLEMAN, NC 27317 UNITED STATES
(336) 676-7283
Oil leak at top of pump
The oil in the pump is probably leaking because a seal is blown and water is getting into the piston housing. Take a look inside at the oil. It should be brown and translucent. If it is gray, white or milky, you have a blown oil seal. This reservoir should only be 1/3 full of non-detergent oil to begin with. Hope this helps
Low water pressure
Water inlet filter lime or dirt , 2 nozzle dirt 3
floss with o-rings valves 1 valve has dirt or broken o-ring between 1 of the valves 4 pressure control valve was not screwed. the nozzle (if it is a dirtkiller) is is broken mostly porcelain.
What is an uploader
I think you mean an UN Loader this is a valve that redirects (bypasses) the pressureized water back into the intake when you release the trigger When it is not working the machine continues to build pressure and will bog down
hope this helps
the ed
