HP Pavilion a706n PC Desktop Logo
Anonymous Posted on Nov 29, 2009
Bestec model atx 250 12z flashes green when hp pavilion a706n is powered on light on back blinks green and pc does not power on even after all cables are disconnected
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Nov 29, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
5965
Points
30
Try these suggestions:
<a rel='nofollow' href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=427167&dlc=en&lang=en#bph06788_section_2" >Troubleshooting Power Supply Issues</a>
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1283
Points
PSU Had died - replaced power supply - all good.
2helpful
2answers
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
3helpful
The green light on the back is flashing, but when I push the power button nothing happens, any ideas what it could be?
The Green LED light flashing indicates a bad Power Supply. Weak voltage power rail.
http://h10025.www1.hp.com/ewfrf/wc/product?product=404643&lc=en&cc=us&dlc=en&submit.y=7&submit.x=7&lang=en&cc=us
Troubleshooting Power Supply Issues HP Pavilion A520n,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=404643#N207
Click on > Power Supply light is on or flashes
"If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced."
Cause?
The leading cause is the computer is dirty inside, to include the Power Supply
The next cause is that Electrolytic Capacitors have failed inside the Power Supply.
Solution is to replace the Power Supply.
The Power Supply used is the ATX form factor. The type of Power Supply used in over 80 percent of PC computers out there, and very readily available.
Size of the power supply case is approximately 6 inches Wide, 5-1/2 inches long (5.5), and 3-1/2 inches Tall. (3.5)
It is a 250, or 300 Watt generic unit, probably made by Bestec, Delta, or HiPro.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=404643
Scroll down to see the illustration and photo of the motherboard.
Power cables needed are;
A) 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
{ ATX power supply's today come with a 20 + 4-pin ATX main power cable.
The power cable can be used as a 20-pin, or a 24-pin.
Add the 4-pin connector to make it a 24-pin, or do not use it, and have a 20-pin }
B) Enough standard 4-pin Peripheral power cables for the IDE (PATA) harddive, {1}, and the optical drive/s.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Today's power supply's come with either at least 4, or 6 of these power cables.
C) One Floppy Drive power cable.
Won't be used for a Floppy Disk Drive on your computer. It's power for the Memory Card Reader.
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
All of the above power cables are typical when purchasing an ATX power supply today.
Need guidance in choosing a Power Supply, please state in a Comment.
Regards,
joecoolvette
Why is my hp pavilion 523w not working it just makes enough power to make a green light flash
The Green LED light you see flashing indicates you have a bad Power Supply.
Computer unplugged from power, computer on a table, computer case open, observe Anti-Static Precautions.
Clean the inside of the computer out with a can of compressed air for computers, (Or may take two, and a few Q-tips), and replace the Power Supply.
Supporting data:
HP Support > Pavilion 523w desktop computer > Main support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=90859&lc=en&cc=us&dlc=en&submit.y=9&submit.x=7&lang=en&cc=us
Click on > Solve a problem > Start Up/Shutdown/ Power > Power Management
Click on the + sign to the left of > Power supply light is on or flashes
Replacing a Power Supply,
1) http://www.fonerbooks.com/r_power.htm
2) http://www.videojug.com/film/how-to-install-or-change-my-computers-power-supply
The Power Supply is an ATX form factor. The ATX style of Power Supply is found in over 80 percent of personal computers out there, and is readily available everywhere.
It's a 250 to 300 Watt power supply.
Probably made by Bestec, HiPro, or Delta, or some other generic power supply manufacturer of low quality power supply's.
Has a 20-pin ATX main power cable, and a 4-pin ATX +12 volt power cable.
Plus the usual amount of 4-pin Peripheral power cables, and a Floppy Disk power cable.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07845&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=90859&lang=en
Scroll down to the illustration and photo of the Motherboard.
Typical 20-pin ATX main power cable,
Typical 4-pin +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
I had a powercut, when power returned, computer would not boot
what you have to is to unlplug the cord then cut the computer on
4helpful
2answers
HP Mod a500n PC, flashing green ps light
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
