yes, the batter can be re placed, but i would verify its charging before buying a battery.
make sure green light is on the car charger (or a known good charger0 and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
after its started, go to the system setting. the battery meter should be moving left to right. if its all green and turns off when unplugged, the battery needs replaced.
your part # for your battery should be
37-00030-001you can get a battery
HERE but verify your unit with the seller.
if it only has a few bars and is not moving while plugged it, it is not charging.
this is a very common problem for the models listed below.
the
following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the
6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it,
hereor buy the port
hereif you need further help, just let me know.
bill
