20 Most Recent
Tomtom One Europe v2 GPS Receiver Questions & Answers
Frozen startup screen
jump up and down on it about 27 times sorry 28 and see if that helps, it did me - i then went and bought a MAP
Download india map in tomtom gps
There are no India maps for tomtom. For India maps you may use Mapking, SatNav or MapMyIndia (best maps but with lousy software).
Changing maps already installed
Hi, Answers to your 2 questions 1 and 2 . ...... 1/ go into PREFERENCES , hit right arow key till you see MANAGE MAPS , Tap that MAP icon and in there will be all the maps you have on the SD card. Select the map you require by tapping the screen. ............................................. 2/ YES , backup the SD card to your PC first. ( you should save everything on the card as it is ) Then delete the Europe map off the SD card and replace it with the USA map . You will need the authorisation code for the USA map in order to activate it. When you return you can swap the maps back again.
Tom tom one won't down load home automatically
First BACKUP your SD card.
Go here and download latest version of TomTom HOME >> For the PC or for the MAC , You can download tomtom HOME here >
http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_adp.php?p_faqid=7408&p_created=1184659653&p_sid=PmvpQQmj&prod_lvl1=&prod_lvl2=&cat_lvl1=&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE1LDIxNSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZG93bmxvYWQgaG9tZQ**&p_li=&p_topview=1
I would recommend you only do a map upgrade if you definatly need to as looking at other posts on this forum lots of people have problems after trying to update maps.
Updating maps is NOT FREE , you have to pay for updates and after downloading updates you need to reactivate the map with your product code . Only do an update after backing up your existing maps other sie you might have trouble reverting back if the download goes wrong.
GOOD LUCK
How do reset my tomtom 20
Press the power button down and hol down for approx. 20 seconds. When you hear the tomtom 'drums' let the power button go and wait about 60 seconds for a full reset and boot
How do i reset tomtom
press the reset switch for 20 seconds or if newer model hold down te power switch for about 20 seconds until you hear the tomtom drums then release
How to backup tomtom
Back to support home page The easiest way to make a backup of all the contents of your TomTom device is by using
TomTom HOME. You can make one backup per device and store it on your computer. When you make a new backup, the old backup for that device is overwritten.
Tip: We recommend setting HOME to back up automatically before installing new content. [
more... ]
- Connect your navigation device to your computer and switch it on.
TomTom HOME starts automatically.
If TomTom HOME does not start, do one of the following:
- Windows 8:
Right-click on the Start screen and click All apps. Then scroll through the list of applications until you see TomTom HOME. Double click to open the program.
- Older versions of Windows:
Click Start > All Programs > TomTom > TomTom HOME.
- Mac:
Click Go in the Finder menu and choose Applications, then double-click TomTom HOME.
Click Back up and restore in the HOME menu.
- Click Back up my device and then click Back up now in the bottom right corner.
HOME backs up your device.
- Wait until HOME has finished creating the backup.
Then click Done.
To see where HOME saves your backups do one of the following:
- Windows: Click Tools > TomTom HOME Preferences and then select the Folder Preferences tab.
- Mac: Click TomTom HOME > Preferences... and then select the Folder Preferences tab.
To restore a backup, click
Back up and restore in the HOME menu and then click
Restore my device.
