2005 CHEVROLET Trailblazer
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3757ALL
Front turn signal
3757ALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
Assembly
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3157LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
194
Dome light
212-2
Step/Courtesy light
194
Trunk/Cargo area
212-2
SOURCE: how to change bulb on drivers side low beam head light
My niece has a jimmy, they should be the same. The inside should be the high beam, the outside the low, DO NOT TOUCH THE GLASS ON NEW BULBS! Oil will cook on them and pop them! Both come off the same way. Take off the big rubber thing. They are soft but over hard plastic. Just pull them off. If you have trouble, you can flip the little wire clips that hold the headlight housing in place, this will give you room to see the rubber caps enough to figure them out better. The bulb assembly rotates CCW counter clockwise, and should slip out easily. Take the wires and plug off. it should be obvious how it pulls off. Snap the new bulb into the wires without touching the glass part. Gently replace in backwards order as you removed it. Put the rubber caps on, they keep water off the bulbs. It will break them!
The passenger side was harder for me. I had to take the air cleaner off, the whole cover and filter.You should be able to see or feel the same type caps, The low beam outside, High beam inside. The same 2 wire clips are there to release the housing. Everything pretty much goes the same, other than the air cleaner has to be removed and replaced. And make sure the rubber cap is replaced! Good Luck and good motoring!
SOURCE: need 02 trailblazer third brake light removal
Open the full hatch.
Pull down the weather strip near the rear dome light.
There should be a wire with a connector in it. Disconnect it
Close the full hatch.
Open just the window hatch. There is 1 screw on either side of the bulb housing.
SOURCE: HOW DO I CHANGE THE LIGHT BULB ON MY HEAD LIGHT ON
Open your hood, look behind the headlight with a light and locate 2-black right angled pieces of metal. The one towards the engine side is easily found, but the outer one is under the metal fender and little harder to locate. Take a long flat screw driver and pry up on them, this will release the healight itself. Then you will have to take a flat screw driver and pry the clips on the top of the grill out all the way to the other headlight( I believe there is four of them). There is clips on the botton of the grill also, but they will pull out by when you pull back on the grill. Make sure to snap them back in when you re-assemble.Then you will have to take out the amber cornering light to allow you to get the headlight foward enough which will allow you to pull the headlight assy. forward enough to get your hand in there and remove the rubber cup like cover with a flat scredriver and then you will see the bulb. Give the bulb a quarter of a turn to remove it . Do not touch the new bulb because of oil from your finger will shorten the life of your bulb. Then reverse what to took apart. The snaps on the grill will just push in again. Good luck!
SOURCE: what's the replacement number for
Should be a 3157 bulb.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
