Texas Instruments TI-86 Calculator Logo
Therese Almayah Posted on Nov 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TI-86 answers every problem with an E answer. example: 3*3=9E0 How do I make it stop doing this? This has always been a great calc till it started doing this.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Nov 12, 2009
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675941
Points
21596
It is still a great calculator and what it is doing now is not the result of a defect. Rather, it is a configuration setting that someone has activated.
The calculator has three display modes for the numbers.
Standard 'normal', scientific and engineering. The calculator respects the user's choice as long as possible, but if the numbers are too small or two large it uses the scientific display format.
To set the 'normal' display format:
  1. Press [2nd][MODE]. On first line of screen that is displayed, make sure that Normal is highlighted. If it si not, use the arrow to move cursor on it and press [ENTER].
  2. Use arrow to move cursor to 2nd line. Highlight the number of decimal digits you want (0, 1, 2, ...,or 9) and press ENTER.
  3. Quit the MODE setting. From now on the calculator will use the 'normal' display format with the number of decimal digits you chose, until you change this setting again.
  4. However if the number displayed is too small or too large it will be display it in scientific exponential notation. Subsequent numbers that are not too small nor too large will obey the 'normal' format.
Hope it helps.
2answers
Why is my ti84 giving me wrong answers when I use trig functions?
Your right you should be in degree mode. However, my guess is you are somehow entering in cot wrong in your calc. Recall cot = 1/tan! In your graphing calculator enter: 35(1/tan(61) = 19.4.
Hope this helped!
What is the cube root function on the ti-86
look under math calc and there should be an x^3 key
I just bought a texas instruments TI-30X IIS Calculator. How do I reduced improper fractions with no mixed numbers. What keys do I press. For example: 3 6/8 X 7 1/3 = ? How do I find the answer?
if you want to use your calc for this you would have to put it in as the operations to change the mixed to improper fraction i.e. input exactly as "((8*3)+6)*((3*7)+1)="  remember?  take denominator times whole number plus numerator and put over denominator to convert from mixed to improper... hope this helps
5helpful
2answers
How do you use the imaginary number with the TI-84 calculator?
If you want the answer in rectangular form, set MODE a+bi and tap ENTER and QUIT. Tap square root sign, tap (-)4 and close the parenthesis and tap ENTER. The answer is shown as 2i.
If you want the answer in polar form, set MODE to re^xi and and DEGREE. Tap ENTER and QUIT. Tap the square root sign, tap (-)4, close the parenthesis, and tap ENTER. The answer shown is 2e^90i. (2 at ninety degrees). If you selected RADIAN mode, the answer would be 2e^1.57i (2 at 1.57 radians; or 2 at pi/2 radians)
IT-86 Both batteries removed, now dead
Use the TIconnect or TIGraphlink software to reinstall the programs. You will find the programs in the TI Program archives.
ftp://ftp.ti.com/pub/graph-ti/calc-apps/86/.
Hope it helps
3helpful
Tan Cos and Sin errors
go to:
mode
select DEGREE rather than RADIAN three lines down.
Ti-84 plus
http://education.ti.com/downloads/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
Hope this helps. It's the guidebook - user manual for the TI84, good choice of calc
Regards, Luda
1helpful
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
