20 Most Recent
Texas Instruments TI-30X-IISTK Scientific Calculator Questions & Answers
TI-30XS won't show square roots
You've got two different issues here.
Square root of 39 IS the exact answer, as the result will be a surd (an irrational number with too many - or potentially infinite decimal places).
If you have been asked to round or show your answer to a number of decimal places then you use the answer toggle (the opposing arrows button above enter) to receive an approximation - a rounded answer (6.24 to two d.p. if you were to multiply these together you will see it is close to 39, but not EXACT, because it has been rounded already). You can also press the answer toggle again to see a longer decimal, but again this is rounded and not exact
2/21/2022 10:20:38 AM •
Texas...
Answered
on Feb 21, 2022
What does statvar mean on
On the TI-30Xii it means "Statistics Variables." It displays a menu of variables with their values.
5/29/2018 3:37:50 PM •
Texas...
Answered
on May 29, 2018
Ti 30xs
We had a similar problem: enter a number like 6.02 [x10n] 23
The 23 is shown as exponent, in small, raised type. How to get out of the exponent is not obvious, but my daughter finally guessed it. The right side of the direction control (>) exits the exponent.
1/26/2016 3:01:18 AM •
Texas...
Answered
on Jan 26, 2016
Syntax error on TI-30XIIS calculator when i press
I had the same problem and finally figured out how to fix it. You need to clear the memory. To do so, first press and release the 2nd button at the top left of the calculator. You will see "2nd" appear on the screen at the lower left. next press the 0 button (which 2nd function is "Reset"). The key to making this work is: do not hold the 2nd button while pressing the 0 button. You have to press it, release it, and then press the 0 button.
9/23/2015 5:08:18 AM •
Texas...
Answered
on Sep 23, 2015
My TI-30X IIS wont turn off!
all u have 2 do is press the 2nd button that is lite blue at the top left hand corner & press the on button.
7/14/2014 3:47:43 PM •
Texas...
Answered
on Jul 14, 2014
What is a cas calculator
Some high-end calculators have a Computer Algebra System built-in. These systems can do symbolic algebra, that is, with symbols instead of numbers, for example factoring a^2-b^2 to produce (a+b)(a-b).
The TI-30x isn't one of them.
6/18/2014 12:01:01 AM •
Texas...
Answered
on Jun 18, 2014
What does deg in display on ti-30x mean
It means the calculator is current set to the degrees mode. Trigonometric function depend on how you measure the angle. The most common units are degrees, radians, and grads. To change the mode on the 30Xa, press the DRG key to cycle through them.
6/13/2014 3:03:23 PM •
Texas...
Answered
on Jun 13, 2014
