FAMILY 3HCPS.0454aa Brake is locked & won't un-lock.
There have been recalls on some model Homelites for this problem. And we have heard complaints about other models that Homelite wouldn't repair. Contact Homelite if no satisfactory resolution; contact your Attorney General, BBB. HTH
Lou
https://register.homelite.com/contact_us/new
Homelite Consumer Products, Inc.
1428 Pearman Dairy Road
Anderson, South Carolina 29625
T (1-864) 226 6511
F (1-864) 261 9435
www.homelite.com
Parent
Techtronic Industries North America, Inc.
T (1-864) 226 6511
F (1-864) 261 9435
www.ttigroupna.com
www.ryobitools.com
As a last resort a local saw shop can probably repair it for $20 or less. Ask them to demonstrate what they did.
Do the brake light work? No brake lights and it won't shift out of park. Check your fuses and check for loose wires. Check your brake light switch. If that has failed, you won't be able to get out of park. The other one if the shift lock solenoid which is in the shifter assembly. The brake shift interlock switch prevents the car being shifted from park unless the brake pedal is depressed. Try to apply power/ground to the proper wires & see if it will activate.. If it does, then the problem is between the brake light switch & that solenoid. Could be the wires or the switch.Make sure the shifter cable is still held down in place at the shifter assembly & under the hood. It is the interlock switch that you hear/feel clicking.It is for the prior generation but may still apply.
Good Luck and hopefully you soon will be on the road again...;-)
