20 Most Recent Homelite Ignition Chip Replaces Points Condenser Xl12 Questions & Answers
Try cleaning the carburetor and blow or clean jets. Then new mix and clean fuel. Start up, and probably set the idling to a little faster to start then adjust for good idle speed so it won't stall. Hope this may help.
Homelite Garden | Answered on Sep 03, 2019
What we normally say is good quality two stroke oil 50-1, two stroke oil from unknown manufacturers 25-1
Homelite Garden | Answered on Jul 10, 2019
The oil ratio is not adjusted to the engine it is the formulation of the oil. You mix your oil the way the bottle states. I have been working on 2 cycle engines since the 70's at a motorcycle, ATV and lawn & garden dealership. If you have doubts about a 50:1 oil do like I do and put 8/10ths of a gallon of gas in you jug and use a bottle of oil for a gallon and mix.
Homelite Garden | Answered on Jul 01, 2019
As with any brushed electric motor both brushes should be changed, it is not good practice to have different lengths of brushes.
Homelite Garden | Answered on Jun 19, 2019
you should be able to replace the bulb. take the model numbers to any mower parts store and they can get you this part.
Homelite Garden | Answered on May 27, 2019
16 to 1 There is a universal synthetic oil that works well for most all 2 cycle engines and causes less problems than standard 2 cycle oil. Also try rec 90 or rec 89 gasoline it contains no alcohol and will stay stable longer.
Homelite Garden | Answered on May 10, 2019
sounds like the needle and seat need to be replaced. the carburetor is flooding out and running in the oil. after you replace the needle and seat i would recommend changing the oil.
Homelite Garden | Answered on May 09, 2019
Always use unleaded gasoline with a pump octane rating of 86 or higher. Never use old, stale, or contaminated gasoline, and do not use an oil/gas mixture. Do not allow dirt or water into the fuel tank.
Homelite Garden | Answered on May 07, 2019
Contact Homelite directly to inquire.
Homelite Garden | Answered on Apr 29, 2019
Homelite Ignition Chip Replaces Points Condenser Xl12 Logo
1 questions posted
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
homelite ut151 item numbers
  • Garden
