Re: power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Its simple to replace, only 1 "specialist" tool is needed, but you can substitute for a small screwdriver.
If you visit
http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/
they have alot of info on repairing dyson cleaners AND they sell the
parts, cheapest ive seen online.
My vacuum had this exact same problem, but was out of warranty because
it was remanufactured. Thankfully, it's a very quick, five-minute fix.
UNPLUG The Vacuum!
Remove the cannister.
Extend the handle and remove it.
Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
Gently pull the front plate off.
The switch on the right is the power button. Remove it,
try clicking it a few times; if it sticks, great! Replace it and
reassemble, otherwise you'll need to replace it.
You can't fix this problem yourself - a repair dealer needs to open up the button and inspect the power switch - call the Dyson helpline, they will find the closest authorized dealer in your area and if your machine is still under warranty it'll probably fixed under warranty for you.
UNPLUG The Vacuum!
try clicking it a few times; if it sticks, great, it should now stick when you press the power button. Replace it and
reassemble, otherwise you'll need to get a new switch.
The on/off switcdh underneath the button sounds like it's faulty and will need replacing. I would suggest caling Dyson in your country with the Serial No of the unit for guidance.
if you push the power button, it immediatley shuts off. It won't stay on
