Kenmore washer. Stop working at Spin cycle and the water won't drain either.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Following is a description of how to take the cabinet off although you only have to loosen and tilt the console back to perform the test.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=8e237bef02efdc4281186cef3d28142d
Check out the DRAIN MOTOR PUMP , it could be clogged with debris & lint , located at bottom , look for a small motor with propeller , take it out , remove any debris , clean it and install it back and try again , hope it helps , AJ
